Question about Maytag Dependable Care LAT9416
Washer is leaking at the bottom of the tub (Maytag LAT9416AAE)
Do I need a spaner wrinch, and is the nut left hand or right hand.
  • 121 Answers
Take a look at the video on this page http://www.appliance-repair-it.com/Maytag-tub-seal.html
Posted on Sep 03, 2010
I just removed one without the spanner wrench, A small stubby flat blade screwdriver and a hammer. This is a LEFT hand thread (Remove it by going Clockwise,)
Posted on Jun 04, 2010
Maytag Washer Model LAT9416AAE - Top tub seal is leaking or where the tub and the shaft meet is leaking. What would the cost be for parts and repair (service fees, labor, etc.)?
The usual charge when i have repaired that is around $375
in addation to the seal a tub bearing would be required since the seal has leaked it very likely has rusted the bearing. To replace those both the inner and outer tub have to come apart,the breakdown would be
Parts--$150
Service Fee $75
Labor $100
labor and service fees vary from company to company and that is probably low,yet it is a great washer and may be well worth investing in to repair
Aug 06, 2011 | Maytag LAT3600A Top Load Washer
Washer leaks on floor while in use .maytag. model # LAT9416AAE
could be pump,tub seal,tub,or a hose. to find leak remove the 2 screws at bottom of front cover and pull out and down after removing the cover you should be able to locate leak. I don't advise trying to replace the tub seal unless you have a lot of time and patience.
Feb 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
How do we remove the tub seal assembly on a mat12cs commercial Maytag?
This is a not a job for the back yard mechanic. There are many things that need to be done carefully. There are 3 letters missing from your model number also... However the procedure is pretty much the same for all models.
NOTE you will need a special tool to remove the stem seal. Unless you have the special tool in hand don't even bother starting the job. Tell any appliance part center you need the tool for removing an Old style Maytag tub nut and stem seal.
1. Remove the front panel
2. Remove the cabinet top / lid by removing the 2 screws in the top front corner of the cabinet. and rotate the top up 90 deg. Be careful of the lid that will swing freely.
3. Disconnect the pump inlet hose from the bottom of the tub.
4. Disconnect the water injector hose from the tub cover.
5. Remove the tub cover
6. Locate the only hex head screw in the side of the agitator and remove it.
7. Lift out the agitator
8. Using the special tool you should have in hand by now.... Remove the wash tub nut and stainless steel washer under the tub nut.
9. NOTE the distance of the inner tub from the outer tub and then lift out the wash tub
10. Next is the stem seal. You first have to remove the allen head lock screw in one of the 4 faces of the tub nut. Then again using that same special tool remove the upper part of stem seal. Be careful when lifting it as you can actually damage the grease seal in the very top of the tub seal upper portion. Once the metal upper part of the tub stem seal assy is removed... there another NOTE of caution...
11. The actual tub seal has a carbon face on the top of it and if you crack the carbon seal it your machine will leak all of the time there is water in the unit.
grab the tub seal as the very base of the seal and gently rotate and lift it off the inner tub sealing surface.
12. Install the new stem seal.... by again gripping it on the bottom only and gently rotate and push it down into place until it seats level.
Reassemble in reverse order of disassembly but make sure you INSTALL the allen lock screw into the stem seal nut face. If you don't the stem seal will come loose and your unit will leak again. Final note is during re-assembly make sure the wash tub is centered.... rotate the tub once you tighten the tub nut and make sure it is not to elliptical if you don't get it right... the machine will gyrate with use in the spin cycle.
Jan 14, 2010 | Maytag MAT12CS Top Load Washer
GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Jun 11, 2009 | GE WDSR2080D Top Load Washer
Maytag LAT9416AAE water level switch, green wire is loose
A green wire is usually the safety ground. If it has a ring terminal on it, it will go to a mounting screw or nut. Find the schematic to be sure. Check Repairclinic.com.
Apr 27, 2009 | Maytag LAT3600A Top Load Washer
Water leaks when filling
Use a putty knife at the top front corners to release the spring catches. Lift up the top. Examine the plastic thing that delivers the water to the tub, it may be cracked or out of place.
Apr 05, 2009 | Maytag LAT3600A Top Load Washer
Spins only with manually start /spin sounds like jet engine
Throw this machine out; it is a piece of junk. Transmission shaft is probably scored up so new bearings will do you no good. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Atlantis MAV9501E Top Load Washer
TRYING TO REPLACE THE STEM SEAL HUB ASSEMBLY. CAN'T GET THE OLD ONE OFF. WE REMOVED THE RETAINING NUT AND THE SET SCREW BUT THE ASSEMBLY DOES NOT LIFT UP. THIS IS FOR WASHER MODEL # LAT9416AAE
that's and old one ..try turning the assembly counterclockwise ..if i remember right it screws off you may need a spanner wrench to get it to start
Jul 20, 2008 | Maytag Washing Machines
Maytag Washer: How to Remove Tub
Under the agitator is a flat nut with notches in it. this nut requires a spanner wrench that will fit into the notches. You can use a large channel lock plier. rotate the nut counter-clockwise. under the nut will be a seal. remove the nut and the seal and pull up on the inner tub. to replace you'll need to replace the seal. if the nut isn't too chopped up, use this to refasten the tub.
Sep 05, 2007 | Washing Machines
Washing Machines Logo
422 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
