Sony KP53S75 Problems
I have a Sony rear projection television ( 53” model KP53S75, serial no. 9519148 RA3A, manufactured and purchased in the year 2000) that has some problems and I am trying to determine if the cost of repairs is worth it, so I would like some specific idea as to the cost of repair. The television has been with me in India for the past four years and was recently shipped back to the USA by sea freight. It has the following problems:
1. The unit will not power up and the self diagnostic light blinks four times. I did some looking around on the internet and it seems to be identified as: “Vertical deflection has stopped so IC509 ( vertical out) is defective or the vertical pulse buffer Q1505 is defective.” What would be a ballpark estimate of the cost of repair? The unit is too large for me to bring it to the shop, so it would have to be a home service call; we live in the metropolitan Washington DC area.
2. The mirror is broken. When the unit did not power up I opened the back for a look and noticed some glass shards inside. When I touched the mirror about ½ of it shattered and fell apart (lucky I did not cut my hand off!); I assume it was fractured in shipment. A search around the internet located a site that sells the mirror for $180. Is this a reasonable price and could a layman replace it? What would be a ballpark estimate of the cost of repair for a home service call?
3. The lamps have never been replaced and the unit is 10 years old, what is their approximate service life and will these likely need replacement anytime soon? If so, what would it cost?
4. Lastly, the inside circuit boards look like the inside of a vacuum cleaner bag; after being in India for four years the inside is coated in thick dust and grime. Perhaps this caused problem No. 1, I don’t know, should this be cleaned up and would a service technician be the best one to do it, what would be the cost?
It’s been a great television and I hate to part with it, but given how much new television prices have come down, and the problems and the age of this one; I don’t know if it is worth it……..
Many thanks
  • 5,138 Answers
Google to Encompass Parts Distribution and type in your Model number they Do list it and Parts as well as Service Manual you can Print out online. If you do not hear sound or anything it could be FBT flyback transfomer Ck hori out put Transisitor and small blue high voltage capacitor 2k they go bad alot.
Posted on Jun 01, 2010
2000 sony kp53s75 tv wont turn on - was working great - no blinking light
This is a failure of the main power supply unit which is the Switch mode power supply- SMPS. You need to remove back panel and check the power supply for possible short in the chopper driver.
please check this link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Oct 02, 2011 | Sony KP-53S75 53" Rear Projection...
My rear projection sony has a green tint all over the screen. Is that a common prob, can it be fixed.? The light indicator above the on off indicator is flashing. Is that part of the prob?
Yes,very common on all DLP TVS.The tv in used a couples years.It will develope sytoms known as a Convergence ICS problems.The shop will repair this problems with parts and labors about $300-350.
Apr 06, 2010 | Sony KP-53HS30 53" Rear Projection...
2002 Sony KP53s75 is it worth repair?
Ok, 5 times is an akb problem, and without red, this tells me one of three things are most likley wrong either the red tube is too weak to produce return current to the akb circuit, or you have a bad driver on the crt board or you have a defective focus block. There are several diagnostics that need to be done to determine which one is the cause, if you are un familure with electronic repair it could be a little hazardus to do, so i don;t recommend it unless you are aware of the issues. If you swap the neck modules with the blue tube, and the set looses blue then it is not the tube. and might be worth repairing. but again if you don't have experience it may not be a good idea for you to try this yourself.
Sep 01, 2009 | Sony KP-53XBR45 53" Rear Projection...
Color not working on 53" rear projection sony tv made in 2000 looks like color is all green is it a tube because of the year
there's a slight possibility it might be your video board, i recommend disocuntdashmerchantdotcom for free troubleshooting :)
Jul 01, 2009 | Sony KP-53V90 53" Rear Projection...
Picture will freeze occasionally for approximately 30 seconds, then return to normal. Switching channels seems to take care of the freezing right away. It is a 53 inch rear projection about 8 years old,...
Good Day,
Try upgrading the Screen refresh rate.Right click on your desktop,properties,in the tab settings select advanced and then select the monitor tab.Select 85-100Hz in refresh rate.
I hope this helps...
Good Luck!
Jun 22, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony 50 inch rear projection television
NO IF YOU DONT TAKE CARE AND PUT SOME UNDER
Jan 19, 2009 | Sony KP-53S25 53" Rear Projection...
Sony Model KP-53s70 (Need a replacement Lenticular/Fresnal screen)
Try here: http://www.tritronicsinc.com/
Or try here, they seem to be able to find hard to find replacement parts, including lenticular screens for Projection TVs:
http://www.tvscreenfinder.com/services
Jul 02, 2008 | Sony KP-53S70 53" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
