Question about Apple iPhone Smartphone
Phone does not ring
My iphone quit ringing, it just vibrate.
  • maxflite Apr 09, 2008
    need help
  • 3 Answers
Tap settings and then sounds adjust volume keys if it doesn't work try resetting your phone. tap settings go to general then reset. Goodluck.
Posted on Apr 10, 2008
SOURCE:
How to removed or turn off the vibration on the phone?
What phone you have would be useful to know but for
Android : How to Turn off Sound and Vibration in Androids Keyboard
Iphone: If you set the iPhone to vibrate in silent mode, it still makes an audible buzzing sound that may bother or disrupt others. If you need your iPhone to stay completely quiet, temporarily disable vibration. You can turn off vibration when silent mode is on, off or both. Tap the button next to "Vibrate on Ring."
Blackberry:
Turning vibration on my mobile phone on or off
  1. Find "Notifications" Slide your finger down the display starting from the top edge of your mobile phone. ...
  2. Turn vibration on or off. Tap the indicator next to Vibrate to turn the function on or off.
  3. Exit.
Nov 09, 2015 | Cell Phones
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
I PHONE WILL NOT RING BUT VIBRATES
There is a small knob on the left of the iphone. If you can see small tiny red dot there, then your phone is on vibrate mode. Switch that on. Your phone will get back into ringing mode..
Cheers!!
Guru..
Dec 30, 2010 | Apple iPhone Smartphone
My iphone doesn't ring or vibrate, but does with earplugs on.
hey bro,
i fix more problem like your's. by change the flex up. with volume+vibrat button+headphone.
change this and all your problem will be good.
memeh Fixphone
Mar 29, 2010 | Apple iPhone 3G
Iphone 3g will not ring only vibrate. The Apple store said there was moisture, but it never was close to water. Tried to reset, and all the setting fixes. Nothing works. Apple said I would have to buy...
try going into the settings on your iphone. Then go to sounds. At the top of that page, it says vibrate and under it it says ring. Make sure that the slider next to the ring tap is on not off. I hope this helps!
Nov 29, 2009 | Apple iPhone Smartphone
Locked on silent-wiil not ring only vibrate
Checked to see if your iphone is set to silent, by the looking on the side of your phone (left) at the top if it red your on silent, if not then your on ring!
Jul 28, 2008 | Apple iPhone 3G
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
131 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
