Question about Garden
Cant find transmission parts for my hoffco lil hoe. It has a Tecumseh engine
Most Honda Parts Fit http://www.lawnmowerstuff.com/163-Honda_FG100_Parts.html
Posted on Jun 27, 2010
How do I set the idle for Hoffco Ll'l Hoe engine
The start setting on most 2-cycle engines are as follows for the jets:
The Hi speed is 1-1/2 turns out from closed, and 1 turn on idle or low. Actually they are the same on 4-cycle too. The idle adjustment screw is a separate screw with a spring on it. This will push the throttle arm to give more or less idle. For more info, go to Partsree.com.
Jan 20, 2015 | Tecumseh Garden
I cant find rings for a tecumseh hm80-155356n
40049 is the Tecumseh Part # for a Standard Ring Set, let me know if you need part #'s for OS Rings
Jan 29, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a Hoffco Lil'l hoe and it will start for a few seconds and then stop. Last year I took it to a local small engine repair shop and they just half fixed it because a couple uses it became hard to...
Make sure your air filter is clean and you are using brand new petrol. If you left old petrol in it it may have clogged up the carb. It sound like no fuel is getting to the spark plug. If you have a rubber priming bulb, press it slowly and regularly to try and keep the engine going once you have it started on starting fluid. Good luck.
Jun 25, 2010 | Hoffco TILLER PRO HOE WITH HONDA ENGINE
What is the gas oil mix? Hoffco Li'L HOE
24 : 1= 1 gal gas to 5 oz oil
May 13, 2010 | Honda Garden
I can not start the engine of small garden implement
if it has a brownish primer bulb on carb, pump it a few times, when cold the choke should be closed"full on". pull rope a few times with throttle depessed till engine pops, then move choke to half position still holding throttle, if all is well it will start and run, after about 10-15 second of warmup, move choke to open"off", if it won't start, i'll first ask has it been stored with fuel in it,the fuel may be stale or carb may need cleaning. pull air filter and try a shot of starting fluid, if it kicks over, you have a fuel delivery problem, if it won't fire on starting fluid, try replacing spark plug, if it still wont run e-mail me and i'll try to help diagnose ignition problem
thisoldtruck2@yahoo.com
Mar 16, 2010 | Hoffco TILLER PRO HOE WITH HONDA ENGINE
Spark plug gap
All these engines have a magneto ignition. The faster the mag spins the higher (better) the sparkplug voltage. So the gap is only set for the ease of starting and is not a huge part of tunning as it is on a car. Try .020 inches.
Mar 21, 2009 | Garden
Garden Logo
553 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
