Question about Garden
WHAT TYPE OF FUEL, STRAIGHT OR OIL/FUEL MIX & WHAT PROPORTIONS ?
    President:
  • 1,561 Answers
Determine if your engine is a two-stroke or a four-stroke. Check the gas tank on your lawnmower or the owner's manual to determine what type of engine you have.
Read the label of your two-stroke oil. Follow the directions on the package to ensure the right mix.
Measure and pour the gasoline in to the empty gas can.
Add four ounces of two-stroke oil per each gallon of gas.
Replace the cap on the gas can and shake the oil and gas to mix. Add fuel to your engine.
Take care.
Posted on Jun 01, 2010
  • 1 more comment
  • Tom Wobensmith Jun 01, 2010
    I've lost the manual & there's nothing on the tank to id what type of fuel or mix to use. The model # is 24A-462G729. It has a 5.5 horse power Briggs & Stratton motor.
  • Sulaimon Jimoh Olayemi Jun 01, 2010
    For almost all modern two-stroke engines, a 50-to-1 mixture is
    recommended. That requires about 2 1/2 oz. oil for every gallon of
    gasoline.Use only two-cycle oil for your mixture.
    Take care.
  • cedmundo Jun 24, 2011
    That specific engine runs on gasoline ONLY! 85 Octane minimum. You don't use a fuel/oil mix. You add oil to the engine separately (5w-30 or 10w-30)
How to refuel a sym jolie 50cc scooter, do you mix oil into the petrol tank, or do you fill the oil and fuel seperatley or does it mix it itself????
Pretty much all are normal petrol in the fuel tank and the oil is on another tank. The oil is mixed as it enters the inlet manifold.
Your manual is here. Section 2-3
ScooterCommunity
Nov 06, 2016 | Sym Motorcycles
I have a Ryobi RPT3000 trimmer. Firstly how do I top up engine oil? And then how do I restring it?
The engine on that trimmer will be a 2 stroke 30cc engine not a 4 stroke.
"Two Stroke Oil" is added to the fuel for a 2 stroke fuel mix in accordance with the proportions specified by Ryobi for that engine. The required petrol/oil mix may be printed on the top of the fuel cap. No other oil is used in a 2 stroke engine.
There are a number of videos on Youtube people have uploaded which will show you how to replace the pull cord on a trimmer.
Dec 28, 2015 | Ryobi Garden
What is the fuel mix required?
Pirelli an amazing walk on Christ The Redeemer
HB 180v home light mix at 32 to1
read it on the oil can, bottle, put 1 gal gas in first a marked clean gas can, and ad oil last watch the gas pump not the can, and stop at what amount of gas you need get 100 percent gas in all your trimmers ,blowers! // if the can you are going to use only has a small amount pour it out it might have water in it and that's another story. Rideau Canal Oil Gas Fuel Mix Tables and watch this neat video Christ The Redeemer!
Aug 21, 2014 | Garden
Tomos dirt bike
is the bike a 2 stroke or four stroke four stroke is just straight pump fuel,if it is a two stroke then it is either premix where you mix two stroke oil into the fuel or there is a oil bottle on the bike uesally under the seat where the oil and fuel mixes itself,a two stroke motor has no valves and has a expansion chamber exhaust which means it is not a staight pipe it blows out in size in the middle of it .if it is a new four stroke ask the dealer wether to use a higher octane fuel for it cheers i hope this helps cheers pete
Sep 10, 2013 | Motorcycles
Won at my kids kempo class gio ya49 model what do i need to do to start it not sure if straight gas or mix also do i add oil anywhere thanx
You are going to need more information before you start this up.
You need to know whether it is 2-stroke or 4-stroke.
You need to know the manufacturer, I see some use 25 parts gasoline to 1 part 2-stroke oil. Other machines use a different proportion.
If it is this manufacturer, mix say 25 ounces of gas with 1 ounce of 2-stroke oil in a separate container and pour into gas tank.
If it is 4-stroke, you will need oil in the crankcase, not in the fuel tank.
Try to find the name of the bike/quad somewhere.
Dec 21, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Just bought a McCulloch 32cc, Mdoel 3214 from a pawn shop with no manual. Does it require mixing oil with the gas and if so what ratio?
Fuel requires 2-cycle oil be added, bar oil is straight from the container.
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 06, 2010 | McCulloch Garden
What oil do you use in the four cycle motor/ 29cc
Generally speaking, if there is a place on a gas-powered device that is labeled "gas" & a separate location labeled "oil" than you will need to use a 4-cycle oil for that machine. If there is just a place to put gas, you would use a 2-cycle oil; however, you would need to read the directions/manual to find out the correct proportion of oil to use, because you will have to MIX the appropriate amount of oil with the correct amount of gas, making a oil/gas solution that you would use for that specific device.
May 31, 2010 | Craftsman 29cc 4Cycle Straight Shaft...
Well since it's a 4 stroke I can't mix it with the gas. I drained out all the old oil and I just need to know the correct porportion of oil to re add to my bike
The proportion is 100% oil, don't mix it with anything. Put in two quarts, stand the bike straight up and check the oil. Add one half quart at a time until it registers full on the stick or in the sight glass.
Mar 09, 2009 | 1991 Yamaha XT 600 E
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
