Question about RCA ViSYS 2-Line Speakerphone
Out of Range message on handsets for not aparent reason
My gigaset c610h wont register
You can try to put the base in registering mode by using the web interface. Check your base user manual for further details.
The other plausible reason: Have you checked the DECT frequency range operation? My base was bought in Europe (1880~1900MHz) and the handset was bought in USA (1920~1930Mhz). So they are incompatible. :-(
Dec 16, 2012 | Gigaset C610h Additional Handset For C610a...
I have uniden cordless phone model dxa15588-2, how do I register handset on base?
1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
5-Make sure your phone is working again after "Registration Complete" shows on the display
Hope this will Help. Thank you for using Fixya !!!
Nov 17, 2010 | Uniden Cordless Phone
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
I have a three hand set GE dect 6.0 one of the handsets will not activate, it keeps showing me "Out of Range" I have tried many times to set it up but it always give me the same message "out of range". Can...
On the handset, look for the "PROGRAM" button and choose "HANDSET SETUP". Scroll through the menu to find "REGISTRATION" and select it. The handset display should then prompt you to press and hold the "PAGE" button on the base unit for 5 seconds and then press the "PROGRAM" button on the handset.
Perhaps you've already tried this process, as you indicated your attempts "to set it up". This is what worked for my GE DECT phones when one of the handsets displayed "Out of Range" after an electrical storm. Best of luck to you!
Jul 09, 2009 | Thomson GE 27907GE1 Cordless Phone
Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Mar 08, 2009 | Uniden TRU8885-2 Cordless Phone
Handset out of range - message
We totally unplugged the phone, made sure the battery was charged and reset the phone as though it was brand new, in other words started from scratch. It seemed to work and the phone is O.K. now
Jan 16, 2009 | Uniden TRU9585 Cordless Phone
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Ou t of range
i just fixed mine! hold # and * together let go and do it again, it will reset.. you will be able to make calls again
Dec 29, 2007 | Uniden TRU8885-2 Cordless Phone
RCA ViSYS 2-Line Speakerphone Logo
372 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
