My machine is refusing to spin! It has worked through the programme but just wont spin the clothes
  • Washing Mach... Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineMy machine is refusing to spin! It has worked - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 01, 2010
Hi, my machine lets in water and starts spinning as if the spin and drain programme is selected, spins then pauses and repeats the process.What could be faulty?
Hi, mine does this sometimes when it is out of balance, sometimes it will keep doing it for 30 minutes before I open it, move the clothes around and rebalance. It does this to keep from throwing the washer drum off its mounts with an unbalanced load. It tries to go backwards and forwards during the 2 minute pause to mix up the clothes to rebalance by itself - sometimes it just can't get it and needs your help to separate the clothes so it can spin without vibrating.
Hope this helps!
Feb 09, 2016 | Washing Machines
My washer wont go into spin cycle. I hear a clicking sound coming from the timer.
It isn't a timer it is a programmer that is probably faulty.
You can test this by setting it to spin in different program cycles.
If it refuses to spin in any , assuming that they are in different places on the programmer,, that may indicate another , different
fault.
A technician should diagnose your fault fairly easily.
Jun 22, 2015 | Washing Machines
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
My machine fills but wont spin or drain
The problem will be in the timer kindly replace the timer to solve your problem
Jan 03, 2010 | Washing Machines
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
Hotpoint WF340 - wont complete programme
hi without looking at it i would think that the control board behind the timer knob has broken down these can quite pricey so shop around before you buy one,hope this helps.
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
