Question about Brother IntelliFAX 2800 Laser Fax
WHAT DOES "PLS OPEN COVER" MEAN ? - Brother IntelliFAX 2800 Laser Fax
    Genius:
  • 1,218 Answers
"Plese open cover" ...check ADF, AND REMOVE PAPER TO MAKE SURE NOTHING IS JAMMED. Switch power off for 10 seconds then back on again.
Posted on Jun 02, 2010
Front or vrear cover open
there are 2 switches regarding this error message " front and rear cover open." so pls. check with the front door right side portion. you can see a small leaver there, pls. check that liver correctly go inside the cover after we close the front door.
other switch at the back door paper exit area. pls. check the door closed properly nor not ? that door control a switch liver attached with the fuser unit.
first switch in the HVPS board and second switch at SMPS.
kindly check it and revert back.
May 05, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Help with cartridge installation
after installing the catridge you didnt close the printer top cover properly. pls close this cover properly.
Aug 25, 2009 | Office Equipment & Supplies
Printer says cover is open
it is a sensor problem.pls clean it & close the cover tightly.
Aug 15, 2009 | Office Equipment & Supplies
Mfc3420c brother just says ''please open cover'', open the cover and it says,''cover open...pls close cover''. power off and on and simply does the same!
I've seen that, the spring on the right that holds the top cover gets bent and stops the carriage. From inside you can push it back out toward the front so it doesn't hit and stop the carriage.
Jul 07, 2009 | Office Equipment & Supplies
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
My fax machine says pls open cover
Very likely you have some paper stuck in the printer. Try to lool for it and remove the stuck paper
Jan 17, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
I AM LOOKING FOR THE ITEM NUMBER FOR THE KYOCERA FS1010
this is not troubleshooting, try going onto their website
Apr 15, 2008 | Office Equipment & Supplies
How to open line my n73
Do you mean opening the backside cover to insert the sim card? Just push the button on the cover backside and pull it from the bottom of the fone. First time it may be hard to push, but it will get loose during use. Hope this helps. If not pls ask me in detail. Thx.
Feb 13, 2008 | Nokia N73 Cellular Phone
Brother Intellifax 2800
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
149 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
