Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Release button that adjusts the straps is broken,
(belt tensioner mechanism) can I buy replacement circular button?
Just bought the Cabriofix. Went home and got upset when the straps wouldn't lengthen. As an excited father I tried to keep calm as I tried and tried and tried again. Good ols Google, put the car seat down and jumped on the net to find a solution. 2 minutes later and hey presto.......the grey button that you press HAS to be pressed FULLY IN. Not just press as it easily does, but with a lot of pressure it will sink in another 5mm or so then this releases the straps. So I'm again happy :-) and pleased with my purchase. Now just got to wait 4 more moths till baby is here. Can't wait !!! Oh and ladies, you might want to trim your thumb nail or you won't be able to press the button fully in, sorry :-(
Hope this helps you all though, and good luck all.
Posted on May 11, 2012
2 Suggested Answers
  • 419 Answers
SOURCE: maxi-cosi tobi strap tensioner not working. able
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Posted on Aug 10, 2010
HOW DO I REPLACE A TOYOTA 2005 RAV4 SEPENTENE BELT
The one on the tensioner pulley is it.
Feb 16, 2015 | 2005 Toyota RAV4
Car overheats, small belt broken on driver side of engine
Replace broken belt asap, you will have to release the tensioning pully whell then adjust to get correct tension, normally needs 1/2" of up down movement on longest side of fitted belt.
Sep 28, 2012 | Ford Taurus Cars & Trucks
Broken Buckle casing and release button.
Hi
What country are you in?
If you're in the UK please contact uk-customercare@dorel.eu or telephone 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Feb 04, 2012 | Maxi-Cosi Baby Gear
Replace serpentine belt
Removal & Installation
  1. Rotate the drive belt tensioner clockwise and remove the drive belt.
    WARNING Never suddenly let go of the tensioned idler pulley. The force of the spring pressure suddenly released may damage the idler pulley mechanism. Always release the spring pressure gradually.
    Fig. Rotate the belt tensioner to relieve tension on the belt-4.6L engine shown, others similar
To install:
  1. Route the belt over the pulleys making sure all the grooves in the pulleys and the belt line up correctly. Refer to the accessory belt routing section of this manual.
  2. Rotate belt tensioner clockwise and slip drive belt over idler pulley on tensioner.
To install:
  1. Route the belt over the pulleys making sure all the grooves in the pulleys and the belt line up correctly. Refer to the accessory belt routing diagrams above.
If for any reason, the tensioner is crooked, replace it!!! Also, install the belt with the writing facing you like you are trying to read a book. This WILL (a trick I learned at Mercedes) prevent even a new belt from squeeling!!
Dec 16, 2010 | 2003 Ford Explorer
Is there an adjustment on the tensioner pully?
the serpentine belt tensioner is spring loaded and has no adjustment. it must be replaced
May 25, 2010 | 1998 Chrysler Town & Country
Straps on back of carseat seem to be put together incorrectly
Those go a certain way and no other. For future reference the way to remove the belts is to release the metal oval under the seat and bring it up thru the holes in the bottom of te seat, then out thru the back. You have to undo the clasp and chest snap. Now....you have quite a problem as the straps are responsible for saving a life in the event of a motor vehicle accident. This being said you can try and slip the doubled over ends thru the end that is most narrow, slides into the track and the wider part snaps over the keeper on the seat itself, a little snapping plastic button. Next it goes under the lockdown and up into the first hole. You will need to compress the adjuster of the locking mechanism to get it up thru. If you can do this the next step is down thru and out the end of the locking mechanism. If the holes are too bound up and wont let the end of the belt thru, you may need to cut off the very end and re-thread it, then fold over the material and resew the end over itself to reform the stop. Cutting a belt is a last resort so make sure you are careful and that it is working properly. Otherwise, go buy a new seat. Good luck
Apr 09, 2010 | Evenflo Aura Elite Travel System
How do I asjust the serpentine belt on a 2005 ford freestar?
It should not require any adjustment. the right tension is provided by the idler pully. If you want to release the tension for serpentine removal or examination release the tension on the idler pulley in the rear of the motor, spin the nut in the center like you were tightening, and the pressure will be released from the serpentine belt. Reversely, the appropriate tension will be given using the same way when the strap is reinstalled.
Dan
Dec 08, 2009 | 2005 Ford Freestar
Ho to replace serpentine belt. cant find anything
There probably won't be any adjustments. Serpentine Belts have be used for 25 or 26 years to my memory ,and have spring loaded tensioners to keep belt tight. So I quess your new to the car world. You release the tension with a long 1/2" Drive ratchet or tool specific for belt replacement. If you need to buy any tools you don't have, your better off leaving it to the pros
Oct 01, 2009 | 2004 Hyundai Santa Fe
Broken alternator belt, need info on replacement, 2001 toyota echo
go to toyota buy a fan belt, i think u can see a belt adjuster need the belt and engine , you just need to adjust the belt to very good tension
May 17, 2009 | 2001 Toyota Echo
Isuzu Trooper V6 2001 multi rib belt adjustment
First, if you're serious about car repair, get the shop manual (helminc.com). Not cheap, but cheaper than ruining your engine.
Second, unless you are confident in your mechanical abilities and / or are willing to use your vehicle as training, leave major work to the pros. A good mechanic is like gold, and just as hard to find.
Third, you don't really adjust the tension. There is a spring-loaded idler that puts just the right amount of tension on the belt. Using the proper tool, you lever the idler to take the tension out and slip the belt off the other pullies. Then take the new belt and rout it just like the old one, lever the idler again, then slowly release it back against the belt to take out the slack.
Piece of cake...
Mar 01, 2009 | 2001 Isuzu Trooper
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
379 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
