Question about Haier DE45EAL Dehumidifier
Dehumidifier DE45EA-L always reads Lo humidity and will not cycle
Even when humidity is high will not turn on. Works if I maually turn it on for continuous operation but I must turn it manually off. Will turn off on full bucket.
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
  • 958 Answers
SOURCE: no longer drawing humidity and condensing into bucket
thermostats are device to control the compressor. you said the compressor is running. if you are sure that the compressor is running, then it could have a leak and it is not functioning as it should. feel the air that is coming out of the fan, it should be a little bit warm, if it is not, and the compressor is running, i would suggest for you to turn it off and seek professional advice on how to find the leak and recharge the system of the unit. it is bad for the compressor to run without refrigerant.
tnx for using fixya,
drcool
Posted on Sep 22, 2008
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
  • 52 Answers
SOURCE: Kenmore Dehumidifier Isn't Running
It sounds like you have power to the unit but a component is failing to start the system get an AC tech to check it.
Posted on Jun 09, 2009
bozcro
  • 867 Answers
SOURCE: Kenmore Dehumidifier Model 580.52650 Says "Bucket Full" - Wrong
the problem is with the switch which is connected to the float arm, try pulling it manually, it shoud turn on and off your unit if working properly
Posted on Jun 14, 2009
Dehumidifier does not reduce humidity.
Good Afternoon Miguel,
I understand that your Frigidaire dehumidifier, model# LAD704TDL, is not reducing the humidity, due to the coils constantly freezing up. I also see that it is located in good temperatures and in a good position. I suggest contacting the manufacturer directly. They should be able to point you in the right direction to having your appliance fixed. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Dehumidifier LAD704TDL
Humidity display window always LO
I would go to a box store and get a guage that displays relative humidity and see where it settels at. Your humid may actually be low.
Apr 11, 2014 | Amana 45 Pint Electric Dehumidifier -...
WE have a model DE45EJ - T. The humidifer is not pulling in anything or making any noise or doing anything at all. It says Lo in the bottom reading.
The "LO" in the bottom reading, Indicates the current humidity extraction setting. If the unit was operating properly not that long ago (A couple of hours), the reason it is not doing anything, maybe that there is no humidity above "LO" = 30% at this time. Once it the humidity level rises above 30%, it should turn ON and function normally.
Also, was the timer set to turn the unit OFF at a specific time?
If the unit wasn't working properly a couple of hours ago.
Check the air intake filter for excessive dirt or clogs. Turn the unit OFF & unplug it before removing the filter. While the unit is OFF, remove the bucket, empty it if needed and carefully replace i, making sure it is fitted properly in to it's holder.
Air obstruction: The dehumidifier requires an minimum of 12" to 18" clear air space around the entire unit.
Hope this has helped you further troubleshoot and solve the problem. To assist you further, in case you have misplaced yours, I am including a link to your Owner's Manual that you can download and print for future reference. http://www.haieramerica.com/en/asset/product/4ba7175e54
Jun 22, 2011 | Haier 45-Pint Dehumidifier
My dehumidifier freezes up and never gets the humidity to the setting I have established. Do you think it is worth repairing??
If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room is probably just relatively low and you probably have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room. Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where it is warmer.
I don't believe you need a new dehumidifier. Just try a few of the simple tips above and see if it works any better and stops freezing up.
Hope that was helpful, thank you and good luck.
Joe.
May 24, 2011 | LG LHD459EL Dehumidifier
"Lo" reading at humidity setting
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end. if this helps please rate me.
May 17, 2011 | Haier Dehumidifiers
The dehumidifier wont work even the lights was on and it show Lo all the times and we do not know why it happen and how can we get it fixed as we live in Oshawa, Ontario?
I found this on the web
Q - Will my dehumidifier work in a cold room ?
A - A dehumidifier will not operate satisfactory in a room that is below 65 degrees F. At this temperature it will become necessary to operate the dehumidifying coil below freezing temperatures in order to reduce the relative humidity to a reasonable valve. Frost on coils usually will appear.
I would imaging that the humidity is already lower than the dehumidifier could get it down to. that's why it reads "Lo" on the display.
Jan 10, 2011 | Haier 45-Pint Dehumidifier
Kenmore 580.51650000 dehumidifier: compressor cycles on and off as it should based on humidity setting but the fan is always running, even with the compressor off. Checked humid sensor. Any other...
fan should turn off when compressor not running, the relay switch is stuck open for the fan, and probably needs replacing, but even if it always runs there is no harm and it only uses like 15 watts
Aug 21, 2009 | Dehumidifiers
LG45EL dehumidifier no longer collects water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 01, 2009 | LG DH404E Dehumidifier
Haier DE45EAL Dehumidifier Logo
171 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Youngman
Michael Youngman
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
