Question about IBM ThinkPad T20 2647 Notebook
How to delete one entry from start up screen. when I start up my laptop there are two entries ''window xp professional''.can I DELETE one and how.
  • 73 Answers
Click Start -> Right Click My Computer -> Properties -> Advaced Tab -> Settings under Startup and Recovery -> Uncheck Time to display list of operating Systems -> Click Ok -> Apply -> OK.
And Restart the computer.
Posted on Jun 01, 2010
How remove error STRTDB80.EXE
*First goto "X:\Program Files\Oracle" -> find and run Universal Uninstaller
OR
*Search and Delete all Oracle entries in the registry and then delete "X:\Program Files\Oracle"
Quote: HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Services\EventLog\Application\Oracle.oracle * Delete
X:\Documents and Settings\All Users\Start Menu\Programs\Oracle - OraHome80"
*Start->Run->Services.msc and see if any Oracle services are running then disable it. Then find and delete the services entry from registry:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services
Sep 10, 2011 | Microsoft Windows XP Professional SP2
Tip
How to solve profile storage space exceeded error
Go to Start and select RUN and type regedit and press enter or click on OK
and navigate to the below key system
HKEY_CURRENT_USER\Software\Microsoft\Windows\Current Version\Policies\System
Once you doulbe click on system you will see some entries like below in right pane
EnableProfileQuota
ProfileQuotaMessage
MaxProfileSize
IncludeRegInProQuota
WarnUser
WarnUserTimeout
You can delete all these values (some may not be present,so you can delete whatever entries available from the above files). and exit the registry editor and restart your pc.
on Mar 17, 2010 | Microsoft Windows XP Professional
Tip
You can no longer access the CD drive or the DVD drive or drives not seen in my...
Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. restart computer
on Jun 19, 2008 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
PUT A DVD IN TOSHIBA LAPTOP and it wont play back
For this issue i am providing two options.
1.You may run the hyperliknks provided below.
Hyperlink to microsoft automatic assistance
Hyperlink to Cd drive autofix
If it fixes the problem no need to follow the below mentioned step.
2. This problem is caused by two Windows registry entries that have become corrupted. To fix the problem, you have to use Registry Editor to delete the corrupted Registry entries. To use this method, you must be logged on to Windows as an administrator.
For this if you are using windows xp then the path to open registry editor will be:
Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters. (dont panic if you dont see lower filter)
    On the Edit menu, click Delete. (or simply right click and select delete)
  8. When you are prompted to confirm the deletion, click Yes.
  9. Exit Registry Editor.
  10. Restart the computer
Now If the operating syatem is windows vista or windows 7 then please follow the below mentioned steps.
Windows 7 or Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.(dont panic if you dont see lower filters)
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
May 30, 2011 | Toshiba Computers & Internet
The iolo system shield would not update
This is gonna be Lengthy process.
First
Uninstall System Mechanic Professional
Open the Control Panel by clicking:
Start>Control Panel
or
Start>Settings>Control Panel
Open Add or Remove Programs.
Locate and select the entry entitled iolo technologies System Mechanic Professional
Click the entry’s corresponding Change/Remove button.
Follow the on-screen instructions to uninstall, restarting the computer as prompted.
Remove the System Mechanic Professional registry entries
WARNING: Using the Windows Registry Editor incorrectly can cause serious problems and may result in an inoperable operating system. Use Registry Editor at your own risk and discretion.
Click the Windows Start button.
Select Run.
Type regedit in the Open field.
Click OK.
On the left-hand side, expand HKEY_CURRENT_USER by clicking the + symbol next to the entry.
Expand Software.
Expand the iolo folder.
Navigate to the System Mechanic Professional folder.
Right-click on the System Mechanic Professional folder and select Delete.
Click Yes to confirm the deletion.
On the left-hand side, expand HKEY_LOCAL_MACHINE by clicking the + symbol next to the entry.
Expand Software.
Close the Registry Editor.
Click Start>My Computer and then navigate to your Local Disk (usually the C: drive) then Program Files\iolo\System Mechanic Professional.
Remove residual antivirus files
Close all open windows and restart the computer
Follow the same process to uninstall the System Shield also.
Reboot the PC after everything is over.
Then install System Shield First, reboot the PC after the installation and check if the update it working or not. Once its confirmed that System Shield's update is working, install the System Shield.
May 30, 2010 | ACDSystems System Mechanic with Bonus Iolo...
I wat to dis play drive
To display drive:- 1).go to start>>run>>type REGEDIT and press ENTER. 2) then go to .HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\ Policies\Explorer 3) in the right pane if you find this type of entry then delete it.delete the given entry:- "NoDrives"=dword 03ffffff 4).and now press F5 to save the changes.
Feb 06, 2010 | Microsoft Windows XP Professional With...
Remove linux from my computer I have a laptop with a dual boot system; Unbutu9.04 and windows xp. I need to remove Unbutu. How do I do it?
Sir,
Follow the steps below.
1 Turn on you laptop and Boot on with Windows Xp
2 After entering into the windows xp go to My computer.
3 Right click on the drive where Linx is Installed
4 Chose the option Format
5 Format the drive with the Format of FAT32
These step will lead you to remove Linux from you system.
Oct 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
Strtdb80.exe
OR
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Servic es\EventLog\Application\Oracle.oracle * Delete
Regards,
Mar 27, 2009 | Microsoft Windows XP Professional SP2
Spyware InstantShare removal
HI
go to start , run , type in regedit.exe
Registeration editor is displayed
go to HKEY LCM _MICROSOFT_WINDOWS/WINDOWSNT_UNINSTALL
Delete the uninstall entry. now go to search in the registery and delete all keys by typing the name and click search and delete.
Now delete all the program files that were installed with the programs
Nov 12, 2008 | Microsoft Windows XP Professional
Down load problems
hi thomas
try this
Log on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
oke
succes for you
cropp
Mar 15, 2008 | Computers & Internet
IBM ThinkPad T20 2647 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
