Question about Car Audio & Video
The display on my Pioneer DEHP880PRS unit just stopped working correctly. While it is engaged, there is nothing showing on the face of the display. But when I disengage it to insert a CD, the display works fine. Any ideas?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Sounds like you may have a bad flexible cable. the cable that goes from the face to the main motherboard.
Posted on Jun 02, 2010
Kenwood KRC 535 - Faceplate stops halfway when turning off unit. When unit on it will play music, but nothing lights up so you don't know what you're listening to. Also cannot change station. ...
There is a fine ribbon cable that links both the main unit and the face plate. Due to the constant movement of opening and closing some of the conductive tracks develop cracks. That is the reason why when it closes half way it looses contact and the motor stops turning. The display illumination track must have completely broken.
You will need professional help to replace it because its a little complicated to access this ribbon cable.Will cost you about 15$ plus labor.
Jul 14, 2011 | Kenwood KRC 535 Cassette Player
Basically I have the same problem that has been displayed a lot on this site. My pioneer DEH-P7800MP display won't show when the face closes. When the face opens up all the buttons and lights and display...
The faceplate and head unit is is attached via a flat ribbon cable. (Caution only continue if you have some courage). If you open the faceplate you will see that the ribbon cable is seated in too a flat connector on the PCB (Printed Circuit Board). This connector has a locking mechanism on it that when locked presses the contacts of the cable to the connector. Ensure that the cable is seated properly and that the latch or the lock is in the locked position. Assuming that the tension lessons when the unit is closed so it draws away from the connector and when the unit is open it pulls tension creating a contact. If you see no signs of mishap on this end of the connector try the other end.
Hope this helps.
Nov 17, 2010 | Pioneer DEH-P7800MP
I have a pioneer super tuner III D 50 w x 4 and i cant get the AUX input to work please help
turn the unit off by pressing and holding the off button. The only thing that should be showing then is the time. Then, press and hold the function buttion. This should display the setup menu. Scroll through the menu by pressing the function button (I think). "Aux" should show up and then press up/down or left/right (not sure again). When it says Aux on or yes, turn the unit back on. Press the "source" button until you get to AUX.
Jan 03, 2010 | Pioneer DEH-P4800MP CD Player
No display
make sure the face is on securely. If the contacts are not connected correctly then it won't work.
there is also a reset button behind the face. its a little recessed round dot you push.
Dec 22, 2009 | Pioneer DEH-P2900MP CD Receiver...
Need to set clock
1) Press the center of the multi-control button (big round knob) once to display the settings mode which appears on the digital display of the stereo unit.
2) Turn the multi-control to until the display shows clock settings.
3) Press the control ONCE to enter this menu.
4) The display wish show the 'Hours' flashing - turn the control to adjust this setting to the correct hour and press the control once to select.
5) The "Minutes" will not be flashing - turn the control to adjust this setting to the correct minute (time) and press the control once to select.
6) Locate the "band/esc" button on the bottom left corner of the stereo face and press once to select and exit the settings.
The clock should now be set. NOTE: There are a LOT of different models of Pioneer car stereos and they will not all have the same menus. The above steps should work on the newer systems.
Sep 05, 2009 | Pioneer Car Audio & Video
Pioneer 7800MP can't turn on
It looks like the flexible cable worn out. Try to replace the cable.
This link may help:
Intermittent display on Pioneer DEH-P7800MP car audio
Mar 24, 2009 | Pioneer DEH-P7800MP
No display
Check the electrical contacts on the back of the faceplate and on the front of the head unit for dirt/other damage. If nothing obvious there I would suggest sending the unit for service.
Feb 24, 2008 | Pioneer DEH-P6400 CD Player
Cd pioneer dehp350
check for a stuck button on the face. Thats what happened to mine. Nothing on the face worked... remote wouldn't work...started pushing buttons untill one "popped" and then everything was fine.
Dec 31, 2007 | Pioneer DEH-P3500 CD Player
Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
