Question about HP 640 Inkjet Fax Machine
My fax will not print at all tried test print and it still will not print ...put in 3 new ink toners and still will not print
How do I know which toner is empty on samsung clp315
  • 1.Log on to your computer and print a test page to the printer. Click on the "Start" button, choose "Control Panel" and then "Printers and Faxes." Right-click on the laser printer, choose "Properties" from the drop-down menu and click the "Print test page" box.
  • 2.Look at the quality of the print on the finished page. If the print is light or faded, the ink cartridge is probably empty or at least empty enough that it should be replaced. You can try to get some extra life out of your toner cartridge by taking it out of the printer, shaking it vigorously and putting it back in. Under normal printing loads, this can give you one to three days of additional printing capacity.
  • 3.Open the printer cover and carefully pull out the toner cartridge. Set the cartridge aside while you open the box containing the new toner. Pull the new toner out but do not yet remove any of the packaging materials. Compare the weight of the new toner with the old one. If the old toner is very light, it is nearly empty and should be replaced.
  • Sep 22, 2011 | Samsung CLP 315 Laser Printer
    Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
    If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
    1.Press MENU # 1 9 3 4. The machine should display TECH.
    2.Press MENU, and ENTER. The machine should display TECH Mode.
    3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
    4.Press ENTER, the machine will show YES.
    5.Press ENTER, there should not be any Toner Low/Empty message.
    6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
    If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
    Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
    Kodak ESP 3 doesn't print black ink!
    Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
    Are you using a manufacturer’s factory new ink cartridge or toner? I
    f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
    If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
    Don
    Feb 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    My fax machine rarely gets used --maybe 20 times in 3 years i have bought 3 new toner cartridges because they seem to dry out,, i have removed and shaken it to get SOME ink out. Is it the drum , am i...
    That really sux. No way should these cartridges fail unless they are totally out of toner.
    A drum should last 12,000 prints.
    Are they refills or Genuine Brother cartridges?
    I would email Brother Tech Support on this issue.
    http://www.brother-usa.com/support/
    Oct 12, 2009 | Brother IntelliFAX 2800 Laser Fax
    ALTHOUGH WE RECEIVE FAX FAX IS NOT PRINTED
    You must go to start than programs than accessories than communications then to fax. find the fax you just recived and print it.
    hop this was of some help. if not contact me for a more detail print out of it.
    thanks Sawdust
    Aug 13, 2009 | Lexmark X342n All-In-One Laser Printer
    Put in brand new toner machines says toner is low.
    plull the drum out...and clean the roller....you will be able to see the ink on the roller where your lines are appearing.
    Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
    How can I get the fax and copy to print clearly?
    Still sounds like a bad ink cartridge, try cleaning the bottom of the cartridge with a Kleenex and soapy water. Dry it off real good.
    Look where the cartridge sits and clean the same way.
    Ink jets are dead technology.
    Nov 11, 2008 | HP 640 Inkjet Fax Machine
    Poor quality fax to fax, copy great, computor fax great.
    beware of generic toner!
    you may need to change out your drum unit
    the drum unit may have been contaminated by the staples toner.
    also clean laser window under drum cartridge.
    Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
    Samsung scx-4521f fax memory received but never print out.
    In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
    Oct 24, 2007 | Samsung SCX 4521F All-In-One Laser Printer
    Received faxes with not print
    Stop playing with it, Return it and exchange it. You have a year warranty.
    Dec 28, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
    Open Questions:
    See all HP 640 Inkjet Fax Machine Questions
    HP 640 Inkjet Fax Machine Logo
    103 people viewed this question
    Seeker5211
    Seeker5211
