Question about Toshiba Computers & Internet
How to switch on wifi on a toshiba L500 1XC - Toshiba Computers & Internet
No seeing wifi network on taskbar toshiba r 200
May be the wifi control has been switched off accidentally.
Aug 26, 2012 | Toshiba Portege R200 Notebook
How can i enable/disable the internal wifi card on my toshiba l455d-s5976 notebook
Click on the wifi icon on bottom right hand side of screen,,go to network and sharing,,,right click your connection on the screen ,,go under properties,,disable ,,and enable options,,,also should have a wifi on off switch ,,be the best thing and easiest,,,should be on right hand side of laptop towords the front,,a switch ,,if not check on the top of keyboard,,either sAy wifi or have icon,,,good luck,,also,,toshiba website ,,support ,,can help ,,
Dec 21, 2011 | Toshiba Satellite L455D-S5976 Notebook
Wifi switch damaged and i need to turn wireless on
You would either need to replace the portion of the case where the wifi switch is located (can't buy just the switch) check on ebay for cheap replacements.
You could if you want remove the wifi switch and hot wire the contacts together (permanent wifi on)
Nov 07, 2011 | Toshiba Satellite Pro L300 Notebook
Don't know how to setup wireless toshiba satellite pro 6100 pc notebook
Most Toshiba 6100s come standard with wireless cards installed. If you're unsure, just turn on the WiFI antenna switch (near its SD card slot) and see if the WiFi access LED lights up (the WiFi LED is the rightmost LED on the front of the unit) -- if it lights up, then you've got a stock Wireless card in your system.
Email me if you can't determine which card you have.
Jan 15, 2011 | Toshiba Satellite Pro 6100 Notebook
I have wifi connection but at work I can't connect because the wifi is blocked, Does the toshiba laptop have a built in wireless card? And if so how do I activate it?
Hi
Usualy the wifi switch is visable either above the keyboard somewhere near the power switch or on the side or front of the laptop it normally has a picture on the switch which looks a bit like a satalite
some you need to press to activate it some you have to slide
hope you find it
Dec 10, 2010 | Toshiba Satellite C655S5085 Notebook
Wifi switch is turned on however, when i try to search for a wireless network i get a message saying that i need to turn on my wireless switch
So I understand that your wifi card doesn't work?If that is correct go to Toshiba site and check their support-from the other computer-of course.If card is dead, you will need usb wifi.
Nov 15, 2010 | Toshiba Satellite Pro L300 Notebook
My Toshiba Satellite L305D-S5940's wifi stopped working
Its posable that the antenna is worn out. Just buy a wifi card and insert it in the slot, they work better anyway!!!
Jul 25, 2010 | Toshiba Satellite L305D-S5940 Notebook
Wifi switch not hooked up - stuck in off, how can I override swit
Did you check to see if the wifi was properly plugged in?
Usually this happens after they replace the motherboards or anything else that makes them unplug things.
I would check to make sure it's plugged in and check the wifi card if it don't plug in and make sure it's compatible.
Happy Holiday
Dec 24, 2008 | Toshiba Satellite A135 Notebook
Wireless does not show up in Network Connections
Did you try - after switching on the "antenna switch" or WiFi hardware - to "Enable" the WiFi adapter, under (XP) Start - Settings - Network Connections - LAN or High-Speed Internet - Wireless Network Connection? (select, right click and select Enable)?
p.s. Once your WiFi hardware is recognized (by Win XP) there is (should be) always a "Wireless Network Connection" in your Network Connections, enabled or disabled, active or not.
May 21, 2008 | Toshiba Satellite M45-S331 Notebook
Computers & Internet Logo
444 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
