Question about GE DWSR405EBWW Electric Dryer
Start switch hums, does not start.
Was working, wife removed clothes, reloaded dryer, pressed start button. Start button hums, does not start the dryer.
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryerStart switch hums, does not start. - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 01, 2010
After drying some clothes the dryer will not start when my wife tries to dry the clothes a little longer
Hey GOD IS GOOD !!!!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Sep 05, 2014 | Kenmore Dryers
Asko T701 stopped running.
Test the wirings to control panel and the switch.
Try also a different outlet, and eventually check with a tester the power cord.
Also the switch must be tested.
If the wirings are ok then the whole control panel can be replaced.
If you want to buy parts you find them here.
Sep 13, 2008 | Asko T701 Electric Dryer
Unit won't start when start button is pressed.
507
is the thermal limit if open due to lint or other problems the dryer will not run.
Of course it could very well be a broken door switch.
I recently worked on a Hotpoint dryer that was eating up clothing.
I took some photos. Hotpoint dryer revamp
Aug 17, 2011 | GE DVLR223 Dryers
Dear Expert, When I went to turn on my Roper dryer it made a humming sound for a few seconds then quit, without out the dryer ever starting. I then had my wife depress the start know while I held the...
check and see if there is any thing in the dryer vent if not.open the door hold the door switch in like the door is shut.have your wife push the start switch in and turn the drum counterclock wise if it starts then the motor has gone bad if it hums still its still the motor.if it does start stop the dryer and try restarting several times sometimes they get a dead spot and it may work for years or may die tomorrow but these are a couple of things to try good luck
Dec 19, 2010 | Dryers
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
May 21, 2009 | Dryers
Gas dryer hums when I press the start button but won't start
hi thats a sign of a faulty motor . replace the motor thanks the appliance doc.
Oct 12, 2008 | Roper RGX4634KQ Gas Dryer
My dryer will not start. It is not locked. I've turned it off and unplugged it for 30 minutes. All the buttons work fine, but the timer just flashes when I push the start button. Help!
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
  • Remove the belt.
Aug 27, 2008 | Whirlpool Dryers
Dryer does not tumble, but heats up
  • Remove the belt.
if this helps please vote me a fix ya
Jul 15, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
GE DWSR405EBWW Electric Dryer Logo
471 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
