My pc wont turn on. when i push the power button, power flashes on then off.
    Guru:
  • 528 Answers
Hi super_jacket. Did you hear a beeping sound the moment you turn on the computer. This migh cause memory or power supply problem. I included a link here inorder to troubleshoot this issue. Please click here.
Posted on Jun 01, 2010
Prestigio multipad 4 diamond 10.1 3g wont charge, but only flashes
Try to connect it to a computer usb and see if it is recognized . Flashing when you push power button means battery is not charged . Flashing all the time when plugged to the power source means it is charging . Try another power cable or check your power input on your multipad - try to move it with toothpick or a pen and see if it is loose or not .
Aug 21, 2016 | Computers & Internet
What does it mean when u push the power button and the words ''chk spkr'' flashes on the display and still wont turn on??
The system connects to speakers with a certain impedance, i.e., 8 ohms, 4 ohms, etc. If you have connected the RCA speakers there may be a bad connection or the speaker(s) may be defective
Dec 08, 2012 | RCA RT2250 System
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Acer aspire netbook wont turn on flashing white light on power button
Did you try to flash a new BIOS? If so, you might be in trouble and
need probably to reflash the new BIOS. (Look at Acer site for info).
But anyway try:
1. Push and hold the Power On switch for 4-6 seconds.
Try to Power On again.
2. If this does not work, do a Power Reset:
- Disconnect powersupply cable and pull out the battery.
- Hold the Power button for 60 seconds a few times.
- Place the battery and powercupply cable.
- Try to Power On.
Aug 04, 2011 | Acer Computers & Internet
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
Power button flashes and wont turn on
Hold the power button till it goes off. Then power it back up sounds like its stuck in power saving mode. let me know
Jul 12, 2010 | Dell Dimension C521 PC Desktop
Wont turn on just flashes.wont turn off just flashes...Is there a reset button??All of a sudden it just stopped and started flashing no warning.
First try to turn off PC by holding power button for more than 5 seconds. Make sure first that your PC is clean inside and CPU is properly connected to motherboard (before you touch inside your PC touch some metal to discharge electrostatic). If it needs cleaning use canned air and paintbrush. Check how memory is connected. Check the Power Supply voltage, if it's ok, first turn PC off,then you can check power button by disconnecting ATX 20 or 24 pin power connector from motherboard and connect paperclip edges to any green to black wires it has to power on your PC. If it's still flashes it's more likely PSU or motherboard issue.
Jan 15, 2010 | HP OfficeMax - CPQ SR1638 NX-B Desktop....
It wont start up, push the power button and screen doesnt come on
Please plug also the power cord to the power source then wait for 10 - 20 minutes to charge the battery of your laptop then after the said time given above please turn on the laptop and see if your laptop is working now. Else if it is not then try to contact computer technician and let that person check the problem of your laptop Most of the problem causes of software and hardware.
Thanks
Aug 04, 2009 | Dell Latitude D505 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
