Question about Western Digital My Passport Essential SE 1TB External USB 20 Portable Black 1 TB Hard Drive
Hard disk not detected
I copied a file from my hard disk to my pc desktop.Suddenly it asked me to save it in a different location or else my hard disk will be correpted.I quickly removed my hard disk from my PC but when i re inserted my harddisk it was not detected.what do i do now?
  • 11,800 Answers
You can't do very much, the damage is already done. The only thing you can do is to remove the hard disk from the case, put it in a pc and try to access it from there - most likely you will have to use a recovery soft to get some of your files back. Once that's done test the disk for faults using HDTune, the free version. If it reports errors, even small ones, then it's dying (or already dead) - junk it and buy a new one.
Posted on Jun 01, 2010
Master hard disc..Message stating that Windows has detected a problem.
Back up your files immediately to prevent information loss, and then contact the computer manufacturer to determine if you need to repair or replace the disk.
+ Start the backup process
* Ask me again later
If the disk fails before the next warning, you could lose all of the programs and documents on the disk.
Immediate steps
Because a disk failure will cause you to lose all programs, files and documents on the disk, you should back up your important information immediately. Try not to use your computer until you have repaired or replaced the hard disk.
Dec 24, 2012 | Computers & Internet
Bios cannot detect hard drive suddenly. I was running the PC well. Trying to start the PC again, cannot go into windows. Check on the bios, no hard drive detect.
Follow the steps given below.
1) First, check your hard disk cable, I recommend you to replace the Hard Disk Cable.
2) If the BIOS doesn't detect your Hard Disk after replacing Hard Disk cable try upgrading your BIOS from the Dell website.
Jul 06, 2011 | Dell Studio Xps 9100 Desktop Computer
I was just copying and pasting files from hard drive to my local disk e but suddenly it stop copying and detecting i even removed it and plug it again but it does not detected
If the driver make a click sound chances are that drive is dead, maybe the heads parks down in a zone not allowed to, etc. You can follow this procedure to try to recover some data in this drive
http://geeksaresexy.blogspot.com/2006/01/freeze-your-hard-drive-to-recover-data.html
Mar 20, 2011 | Computers & Internet
Hi there... suddenly my USB Seagate Barracuda 7200.11 External Harddrive is not working any more... unknown device is the message of windows (WINDOWS 7)! The mistake code is Nr. 43! Could you please help...
Check that the power-brick is supplying power to the disk-drive.
Check that the "data" cable between the computer and the device is tightly connected, at both ends. Try a different cable.
Disassemble the casing, and remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer. If it is detected, then it is the USB-to-disk-drive adapter, inside the case, which has failed.
Search online for a professional "data recovery service".
For a large fee, they can repair your disk-drive, just long-enough to copy all your files to a working disk-drive.
Aug 20, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Cannot format..
Wehn you power up the computer press F1 or F2 or 'del" key to enter in bios then check there your harddisk is detected or not.
Also check sata is disable.
then save settings and exit.
This error comes becasue of your harddisk is not detected proeprly .
Aug 15, 2009 | Computers & Internet
160GB SEGATE freeagent external harddisk is not detecting in computer
it seems your hard drive is having problem, just ask your vendor from whom you have purchased the hard drive to help you.
Apr 21, 2009 | Computers & Internet
I think my operating system needs to be reloaded I had a virus hit and now it doesn't work correctly and i want to save all my file & pictures before anyone works on my computer, how do I start?
If you have a second hard drive inside the pc you can copy them there. Otherwise you'll need to copy to a CD or USB drive. The hard part is going to be figuring out where all your files/pics are located at. You can do a search through windows explorer by extension on the whole C: drive. Ex. search for all *.pdf files for Adobe, all *.jpg for pictures. Also be sure to save your profile as it contains your IE Favorites, My Documents, My Music, etc.
Apr 13, 2009 | Dell Dimension 1100 PC Desktop
Maxtor hard drive installation
Its a long process! First you have to transfer your saved files to disk. CD,DVD, or Floppy. Insert your copy of windows Install disk and turn your computer off and then back on. When Windows asks you if you want to repair or install a fresh version of windows, click fresh version. Have your copy of Serial Numbers ready for your Windows disk. Somewhere in the installation Windows will ask you if you want to install windows to the same drive? Delete this Partition? or Create a Partition?, Know how many Gigabyte or Megabyte your Hard drive is. Click on Delete Partition, Your Hard Drive is now Un-allocated. Now Click Create Partition and enter the amount of Bytes you want to allocate to C: drive, Usually half of what the computer is showing you what you have. Now you have a primary drive of C: and Un-Allocated space, Scroll down with your arrow key and select the unallocated drive and click create drive, the remainder of bytes on your drive will be allocated to that drive and assigned a different drive letter. (D) or what ever. Go back up to C: drive and say install windows to that drive, and from there just follow the windows installation. Good Luck.
Oct 27, 2008 | Computers & Internet
Hard disk
first be sure the drive is a vaible drive.....meaning it should be in it;s originbal PC it came out of and able to boot up on the installed OS. If it can then you are in luck..... install the drive you want to copy to as a slave and use a program like DriveCopy or Norton Ghost to copy the entire drive.....or if you are just after select files, you can use the copy/paste method to the drive. By trying yo use the drive in a different PC it will not boot since it has the other PC's drivers on it =( If the drive will not detect in it's native machine then most likely the drive is lost (unless you pay to clean room recover the contents....spendy!) Let mem know if you need more help!
Jay
Jul 30, 2008 | Computers & Internet
Save data
you get hard disk case and insert your hard disk into the case then you connect it to pc that has os you can now copy your file to the pc
May 30, 2008 | Sony VAIO VGC-V517G PC Desktop
Western Digital My Passport Essential SE 1TB External USB 20 Portable Black 1 TB Hard Drive Logo
749 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
