Question about Oster Golden A5 1-Speed Universal Motor Clipper 78005-010
Can't get the blade to attached to the motor part!
  • Oster Master
  • 1,610 Answers
The blade should be installed with the clipper running. See diagram below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d
Posted on Jun 04, 2010
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
How is the fan blade separated from the motor
Should be 2 screws attaching it to motor . 2 screws per blade. They may be above lite kit to where you can't easily see them and the screws are same color as blade arms .
Jan 24, 2012 | Lasko 3300 Wind Machine Fan
Evap fan noisey. this is the 2nd one I put in.
The fan can not be allowed to vibrate (firmly attached). The motor shaft must be straight. Every blade on the fan must be of the same weight and pitch. Every blade on the fan must be equidistant from each other.
In the event a fan begins to shake, the shaking will cause problems in the other. ie: A bad blade will quickly cause a bad motor. A bad motor will quickly cause a bad blade.
Did you replace both the motor and the blade simultaneously?
:o).
Jun 04, 2011 | Refrigerators
Can I buy only fan blade? My one got broken
All of the fan blades are one piece along with the hub which is attached directly to the motor pulley (if fan is like the fan which is pictured).
This is true even if there is some kind of attachment between each blade and the hub -- it comes as one piece.
If you can purchase it, or another which will function like it, there are two places you may go to: 1) Sears sells parts for everything they sale. If you didn't get your fan from Sears, then you can still go to Sears and possibly locate a fan which is close enough. 2) Appliance parts stores (like A&M Parts/Johnstone supply) sell fan blades.
Before you begin, remove the broken fan blade (including hub). Matching the diameter and pitch of the blade and the hub to motor attachment is the goal. It can only be of good to know the make and model, but it is not necessary.
:o).
Jun 04, 2011 | Lakewood 16" Stand Fan
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
Can you tell me what is causing my delta mitre saw motor to run but the blade does not spin powerful enough to cut moulding?
Maybe the bolt which holds the blade on is loose. If the motor is on the RIGHT side of the blade, then the bolt has 'left-hand' thread. Turn it counter-clockwise to tighten.
Jun 19, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
Blower motor location for 2000 Caravan
The motor is located just under the glove box on the passenger side. I remove the glove box then the panel below the glove box. I also go ahead and pull back the carpet and the padding under the motor. It is held in place by 3-4 bolts that take a 7-8 millimeter socket. I use a swivel extension for the back bolts. The motor with the fan blade attached is a tight fit, just keep wiggling and pulling it should come out. Try to remove the old moter without cracking the fan blade, because sometimes the replacement motor doesn't come with a blade
Sep 17, 2008 | 2000 Dodge Caravan
Health & Beauty Logo
148 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
