Question about Toshiba Satellite 5005-S504 Notebook
Unable to get to CMOS using any of the 3 methods
Neither of the 3 posted methods of entering CMOS will work. Using the ESC key when powering up will display "Use F1 to enter the default setting". However when F! is depressed the system continues to load Windows (XP Prof). I downloaded the Setup Utility but when it finishing unzippind and runs the install program the message "You can not install this program". So, how can I get to CMOS or the setup program?
  • Dummie2 Apr 09, 2008
    Using F2 key on power up will load OS and not enter setup.
    Using ESC key ALWAYS stops at F1 to load defaults.
    Using F2, F10, F12 or DEL keys will not allow entering setup
    Am I using the wrong sequence?
    Still unable to enter setup.
This machine is one of the first "legacy free" models which means there are no BIOS options to change. All settings and resources must be assigned by the OS.
For details, please check the "legacy free" FAQ on MS Knowledge base.
If you are trying to access the BIOS to change boot order so that you can boot from a CD, hold down the 'c' key during POST/boot. This will case your laptop to boot from CD-ROM.
Posted on Jan 06, 2009
If you dont know the answer please dont give input
Posted on Sep 27, 2008
  • 236 Answers
Usually, it is the DEL key that will get you into the setup... If there is a "post" logo (ie, Emachines logo) then you press ESC, then DEL....
Or you can try the following:
F2 key method: Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
Esc key method: Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
Posted on Apr 09, 2008
  • Dave MacPhee
    Dave MacPhee Apr 10, 2008
    Have you tried the HWSETUP.EXE program in Windows?
  • Dave MacPhee
    To use HWSETUP.EXE
    1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
    2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
  • 472 Answers
Pressing F1 is in general the key to set things to default, then carry on, not enter the bios where you want to go.
F2, F10, F12 and Delete are the keys you need to access the bios page. Only one of course, not all together.
  • Anonymous Apr 10, 2008
    Ok, just found your user manual.
    Hold down ESC and turn the power on
    Then you will get the message to press F1 to enter SETUP from there.
    That should solve the problem =)
SOURCE:
Skips CMOS setup
The BIOS information is typically found at or near the top of the POST screen for a very short time
ALR PC non / PCI =CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaultsusing the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
this will reset your cmos
Jan 25, 2014 | Medion M3 Composer 5200 PC Desktop
How to reset cmos in dell e521 dimension computer
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS if you have changed any of the BIOS settings by mistake you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer.. this will reset your cmos
Feb 27, 2013 | Dell Dimension E521 (D10E16) PC Desktop
Can t start my bios
Award BIOS = DEL
hope this helps
Sep 17, 2012 | Siemens Fujitsu SCENIC T PC Desktop
What does check your CMOS mean?
Your cmos battery is dead and needs to be replaced.
Jul 14, 2012 | Toshiba Satellite Computers & Internet
How to go yo bios in compaq nr4000
Award BIOS = DEL
hope this helps
May 10, 2012 | Compaq Computers & Internet
Can you remove cmos from acer aspire 7520
Cmos is located in BIOS
if you remove the cmos your computer might/will not run
if you have changed or need to reset your cmos
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS
using the arrow keys you can load failsafe or optimised defaults
hope this helps you
Oct 30, 2011 | Acer (ACERMOTHERBOARD)
Unable to get into BIOS SETUP
hi there,
On most systems, the key or key combination to press to enter the BIOS program is displayed on the screen when the system boots up, at the time when the BIOS is ready to enter Setup.
take a look at some default keys:-
  • {Delete} (modern Award and AMI BIOSes)
  • {F2} (modern Phoenix BIOSes)
  • {Ctrl}+{Alt}+{Esc}
  • {Ctrl}+{Esc}
  • {Alt}+{Esc}
  • {Ctrl}+{Alt}+{S}
  • {Insert}
  • {F1}
Apr 10, 2008 | Toshiba Satellite 5005-S504 Notebook
Problem with keys used to enter the cmos
For Toshiba notebook PCs manufactured since the introduction of Windows XP, one or more of the following methods will be effective:
  • Toshiba Hardware utility method: Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
    If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below).
  • F2 key method: Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
  • Esc key method: Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
For more information search on toshiba web.
Thanks
iqbal
Mar 17, 2008 | Toshiba Satellite 5005-S504 Notebook
To unlock my mobile
IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Solution: Because of the wide variety of computer manufacturers and BIOS manufacturers over the evolution of computers, there have been numerous different ways to enter the BIOS or CMOS Setup. Below is a listing of the majority of these methods as well as other recommendations for entering the BIOS setup.
Notice: If you are unable to get into the BIOS or CMOS setup because of a password please see document CH000235.
New computers Thankfully, computers that have been manufactured in the last few years will allow you to enter the CMOS by pressing one of the below five keys during the boot.
A user will know when to press this key when they see a message similar to the below example as the computer is booting. Some older computers may also display a flashing block to indicate when to press the F1 or F2 keys.
Press <F2> to enter BIOS setup
Tip: If your computer is a new computer and you are unsure of what key to press when the computer is booting, try pressing and holding any key on the keyboard. This will cause a stuck key error, which may allow you to enter the BIOS setup.
steps dont work for ya above:Try this :
Go to start
control panel
Click on User account
click on computer administrator.
Dec 04, 2007 | Gateway M305CRV Notebook
Toshiba Satellite 5005-S504 Notebook Logo
808 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
