Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer is not pumping out cold water but the hot water is coming out perfectly. tested water pressure which is fine in cold line
    President:
  • 1,430 Answers
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Jun 01, 2010
Will not fill with water cold or hot
Good Afternoon Friend,
I understand that your Frigidaire washer, model# GLWS1339EC, will not fill with cold or hot water. I also see that you have tested the valve, the water pressure, and made sure that there wasn't any blockage in the water hoses. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why your washer will not fill with water. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Frigidaire Gallery GLWS1339EC Top Load...
Cold water not coming in. Hot wash is fine with hot water only. Cold or warm wash pulls no cold water. Water pressure is fine, no pipe kinks. Could inlet valve be stuck? Any other possibilities?
Hi just read your posting.Now have you removed the cold water hose from the machine end and checked to see if there is water coming from the hose?Do any fault codes appear on your machine when the cold water is not coming in?Have you or can you borrow an electrical test meter to test the coils of the valves to see if they are faulty?Please reply with additional information on these questions and I am sure I can help you rectify this fault.
Aug 10, 2010 | Fisher and Paykel IWL12 Top Load Washer
My water in the kitchen has a problem. When I turn the hot water on, the water pressure is very low and a load noise starts after a minute or less and the water starts to slow down. The dishwasher runs ok...
change the water inlet hose screens as they are plugged,also put the hoses on a hot water line and run hor water thru them and see what comes out of them in the sink,then replace the washer inlet hose screen
Mar 14, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Pressure washer has no pressure coming out
I think yor hot water softened one of the pressure seals and has allowed it to buccle. This will drop the pressure away from the pump. It will require new seals to be fitted and the cost is close to $200.
Aug 14, 2009 | Garden
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Mixed Water Fill Causes Issues with Water Pressure
You will have to be specific about what problem the pump is having. It seems to pump ok for everything else. Could the hot solenoid be shorting and sending electricity down the water to bother the pump? Solenoids are not real expensive, try a new one.
Apr 25, 2009 | Kenmore 22422 Top Load Washer
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Washing machine will not fill w/ hot or cold water
Could be an air lock in the water pipes,turn off the water to the washer, disconnect the hoses, and hold them over the sink or into a bucket, then turn the water taps back on to the washer.
The water should come through at full pressure.,
If it does not , then the problem is with your supply and not the washer.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | GE WBSE2090A Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De GO PATS
