When replacing the 12ax7a tube in my ampeg ax-70, what should i replace it with and what is involved in replacing it? is it simply pulling out the old one and pushing in the new one?
  • 4,234 Answers
The short answer is 12ax7a and yes. If the problem is a defective tube, then replace it with another of the same type. The tube will be tight int he socket adn will require a tipping slightly in a circular motion to work it out of the socket. Pay attention to the key (space) when inserting the replacement.
Dan
P.S. Depending upon the sound you want, you can replace the 12ax7a with a 12au7 to get a softer sound. Both tubes are pin adn circuit compatible.
Posted on Jun 07, 2010
    Champion:
  • 211 Answers
Simple, just wiggle and pulling.
Then wiggle and pushing.
Watch the empty place on the socket and tube.
regards,
Gerard
Posted on Jun 01, 2010
My buddy recently gave me his svt-6 pro amp head and there is barely any volume coming out of it when its cranked
Assuming you've tried other known working cables, speakers, and instruments, I'd suggest just taking it into a pro repair shop. If you start poking around inside without knowing what you're doing you risk frying the amp further or perhaps frying yourself.
Mar 08, 2016 | Ampeg Svt 6 Pro Amplifier
Tip
Clear BIOS Password, All tricks !
1.png?v=20100715113854 At command prompt type debug
you will get a - prompt where you can type the fallowing (<enter> means hit enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
on Jul 16, 2010 | Computers & Internet
I have an ampeg tri ax vt 60. Probably from 80s. I need ANY information on wiring please. Its been taken apart HELP
This does not sound like a motorcycle under which class it is posted. Maybe try guitars or amplifiers if that is what it in fact is.
Nov 18, 2014 | Audio Players & Recorders
Changing bulbs on 70's toshiba receiver
When you say bulbs I am asuming that you mean tubes? Some receivers you can just pull the tube out of the board because it just snaps in. If you do not have a set up like this then you need to unsolder the tube from the board and then you can replace.
Mar 20, 2013 | Toshiba Am/fm Stereo Receiver Sa-300
Reset forgotten bios password on a pavilion ze5600 laptop
click start type cmd press enter
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten hope it helps
Aug 31, 2012 | HEWLETT-PACKARD Pavilion Ze5600...
How to replace an output transformer in an ampeg svt6pro
If you want to sell the damaged amplifier.
I'll buy you.
Apr 25, 2012 | Ampeg Svt 6 Pro Amplifier
While playing, the power cord was accidentally pulled out. When plugged back in, the amp cuts on, but there is no sound and the led lights for peak and tone selection flash.
You have probably blown a tube. This amp has one 12ax7 and one 12au7 in the vintage preamp. You can try replacing the preamp tubes, but it can be quite dangerous if you don't know what you're doing!
Sep 20, 2011 | Ampeg BA600-210 Bass Combo (with )
I have had my ampeg svt 6 pro for a few years, never any problems until now. I just had a tone pot replaced. Now when i turn it on the fan is blowing at the max and the power light does not turn on and it...
first about the pop noise it caused by the Board inside the AMPEG need to be welding
second the power light simply check the 5v in your power supply
Jul 27, 2011 | Ampeg Svt 6 Pro Amplifier
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
All the inputs on my ampeg bass amp are not working even the RCA input is not working. the amp still turns on
If none of the inputs work, then you may have lost part of the power supply. DO NOT go into this amp under any circumstances !!!!...there is enough voltage in here to kill you crispy !! I would strongly recommend that you take it to a respected repair shop that specializes in guitar amps. Possibly visit the ampeg website for an authorized repair center. It might cost a few bucks, but the Ampeg is highly sought after by musicians everywhere !!!....thanks... Rob
Sep 01, 2010 | Ampeg Classic Series Svtvr 300watt Tube...
190 people viewed this question
 Grubhead
Grubhead
