Question about Boating
Hi I have a Bombardier 2001 RX sea doo worked fine last year Ive put the battery back in and have nothing at all I have checked all fuses changed battery checked with Ohms test that the leash switch is working but still nothing I'm worried its the central board thats a sealed unti ive checked it's getting power what tests can I do considering it's 700 euro bit of kit not so keen to change it befor I'm sure help!!
  • 313 Answers
SOURCE: DW087K
check first the connection male & female if not loose.
if not` have to send unit in state for repair.
Posted on May 28, 2008
SOURCE: sw 1501 no sound output
in my dvd dts audio is not playing
Posted on Feb 14, 2009
Barkalow
  • 58 Answers
SOURCE: My Xbox 360 has sound but no Picture
This happened to my first 360, and in my case, it was a hardware failure. You can call Microsoft and hope your warranty is still good, and they'll fix it free of charge, but if its not, then you have to pay a fee.
Posted on Apr 01, 2009
SOURCE: 95 ford ranger windshield wipers dont work
There is also a box inside the radio compartment area where the radio mounts that has the door open / key in ignition alarm. If someone unplugged this to disable the annoying ding ding ding; it will also disable the wipers. I wouldn't want to tell on myself but I guess I just did.
Posted on Jul 24, 2009
AndrexT
  • 15239 Answers
SOURCE: RT80A/P Intermittant Power
This could be two things, or three perhaps.
check the seals around the prop as water may be entering the unit. The motor might be seizing with heat. Not sure if it is a brushless motor, but next time it stalls, tap the motor head with a rubber mallet as it may re-seat the brushes if the motor has them.
After 4 years, salt water and storage, it will be overdue for a proper service.
Posted on Nov 21, 2009
Testimonial: "thank you for the quick response! you have led me to a path that I had not considered yet!"
Why does my 1995 seadoo bombardier shut completely down while wide open
Very likely a cracked wire on the ignition-advance. As the throttle is advanced so is an advance-lever that causes the wiring attached to it to Flex, causing an intermittant loss of current to the coil/CDI.
The flywheel may have to be removed to repair/replace the wiring.
Aug 16, 2014 | Tempest SeaDoo/Sea-Doo/Bombardier Jet Ski...
What do I need to do after 10 years of storage.To put a 1992 Sea Doo in water?
Change fluids, Check hull for bouyancy flaws, replace plugs, clean carbs or rebuild them. Most old engines get gummed up after long term storage if the fuel was not completely drained. Another possibility is that the bearings may be damaged from years of condensation and and drying. It happens sometimes and sometimes you just get lucky. Had a ducati paso 750 that blew the race on the bearings because they were deteriorated after years of storage in climate controlled space. Was fine then one day the bearings came apart in the engine and chewed it up.
Jul 18, 2014 | WSM 1992-1996 Sea Doo Gts 580cc Jet Ski...
Where is the battery located in a mercedes ml-320 2009
The battery on a 2009 Sea-Doo is located in a small compartment located at the back left above the water jet. The Seadoo was a model of personal watercraft produced by Bombardier Recreational Products from 1989 to 20031. The XP is a significant model in that it was the first high performance version of a runabout (or sit-down) watercraft to be offered by any manufacturer. ---------------------------------------------------------------------------------------
Auto HID Xenon Light
Jan 22, 2013 | 2007 Mercedes-Benz ML350
2002 gti sea doo wont turn over on the first try
if you have one of the kill cords that is round and it snaps onto a round button that has a silver dot in the center that when the kill lanyard is snapped into place makes a connection to the silver part inside of the kill lanyard itself. most the time its because it is still verifying that it is the right key. they are programed to match you CDI box/ignition module of your ski. this prevents theft. if you clean both the key and the button the key connects to with some rubbing alcohol to insure a good clean connection will most likely solve the problem. when you put the key on the ski you should hear a beep then wait 5 to 10 seconds before hitting the start stop button . that gives the ski time to recognize the key is in fact the correct key to the ski.. hope this helps
Jul 25, 2012 | New Ray 112 Scale Bombardier Sea-Doo XP...
1998 Bombardier Sea Doo leaks, after water gets into the engine compartment it runs badly. Our local seadoo mechanic can not find the leak. Any suggestions? Thanks
pull out the spark plugs and put the cooling line on the motor and turn on the water see if you have a crack in the cylinder walls or a blown head gasket.
Apr 30, 2010 | Boating
Boating Logo
62 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
