Question about HP f2105 21" LCD Monitor
F2105 hp monitor went to sleep and cannot wake.
F2105 hp monitor went to sleep. Unable to wake. Will flash for one second when you press the on/off button.
  • 31 Answers
I cannot help you its either your moniter or the vga port at the back of you tower there the only things i can figue out
Posted on Jun 01, 2010
HP f2105 Monitor In OSD Lockout Won't come out of Sleep mode
try press f4 or shift f4 on your keyboard or Alt+cntrl
hope it helps
Nov 01, 2011 | HP f2105 21" LCD Monitor
Everytime I turn on moniter it goes into sleep mode and won't wake up!!
If there was something wrong with the monitor itself it wouldn't go to sleep it would just turn off. It sounds to be as if there is an issue with the signal going to the monitor itself, try restarting your PC and ensure that the connection on the back of the monitor and the connection on the back of your PC are secure.
Mar 07, 2011 | HP f2105 21" LCD Monitor
I have a hp monitor with the number hpf2105 on it
Please see my profile for instruction, or try below, you should also download user manual from HP:
? OSD Lock —The OSD can be enabled or disabled by
pressing and holding the Menu button on the front panel for
10 seconds. If the OSD is locked, the warning message
“SD Lock”displays for 10 seconds.
?If the OSD is locked, press and hold the Menu button for
10 seconds to unlock the OSD.
?If the OSD is unlocked, press and hold the Menu button
for 10 seconds to lock the OSD.
May work the same on other HP model also.
User manual: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=447388&
If you want to see the inside of your monitor, look here:
http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | HP f2105 21" LCD Monitor
HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
Post back what you find so we can guide you further
Apr 03, 2010 | HP f2105 21" LCD Monitor
My screen keeps going dark like it is going to sleep
Right click on any free space of desktop and go to properties and go to Screensavers tab and click on Power Tab and select Never in Turnoff monitor option and click apply OK.. now it will not go dark..
Soluzia.net
Jan 07, 2010 | HP f2105 21" LCD Monitor
Monitor says it is going to sleep and there is only a black screen.
Monitors go to sleep when there is no computer activity it detected. Also, when your OS is working and somehow you have set a "sleep" time, then the monitor goes to sleep at the appointed time. Just press ENTER or press the POWER BUTTON to bring it back to life without losing your computer work.
Oct 29, 2009 | HP f2105 21" LCD Monitor
Hp f2105 monitor goes immediately to sleep mode
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
Sep 07, 2009 | HP f2105 21" LCD Monitor
Monitor went to sleep and won't wake up
It sounds like a driver issue, but more likely the monitor driver, not the video card, since the other monitor works properly.
If you go into the video properties, check the monitor settings. You should be able to switch it to a generic monitor. You also need to make sure that you have the correct monitor refresh frequency set. If you have a mis-match, the video card could send signals at a rate the monitor can;t handle, which is why it won't "wake" even after a reboot and might need to be unplugeed to get it to come back on.
Jan 01, 2009 | HP Pavilion dv6000z Notebook
My hp w2207h goes to sleep
Turn off the "powersaver" feature on your monitor by pressing <menu> then <management>then <powersaver> select off.
Nov 20, 2008 | HP f2105 21" LCD Monitor
Sleeping Monitor
check your video card remove from the system then clean up the gold tip second remove the memory then clean up the gold tip then put it back to the board then restart your CPU
Apr 16, 2008 | HP f2105 21" LCD Monitor
HP f2105 21" LCD Monitor Logo
450 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
