Question about Briggs & Stratton Garden
Timing marks on a 6.25 hp engine
Timing marks on a 6.25 hp briggs & stratton engine
    President:
  • Briggs & Str... Master
  • 1,545 Answers
HOW DO I GET A REPAIR MANUEL FOR A BRIGGS AND STRATTON 12 HP IC QUIET ENGINE
Try website for Briggs & Stratton. Or use Google Search for Briggs & Stratton 12 HP IC Quiet Engine Manual.
Oct 02, 2014 | Heating & Cooling
How to set timing marks for briggs 310000
there re marks on the cam and rod gears line them all up if overhead cam there is marks on the cam that need to line up flush with the head
Sep 13, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 6.5 hp 120000 series mover engine. How do I set the valve timing gear ?
The crankshaft should have a marked "tooth" either with a "dot" or a "-"mark, the camshaft will also have a corresponding dot or dash. By rotating the crankshaft, align the marks on the crankshaft & the camshaft so that they are directly opposite each other. Drop the camshaft into place and the engine is now "timed"--if the marks are not exactly opposite one another, lift the camshaft (just enough to disengage the gear teeth) and try again, being "one tooth" out can make a huge difference--so take your time and make sure the "marks" are directly opposite each other.
Aug 08, 2010 | Briggs & Stratton Briggs Stratton Intek V...
What kind of oil does the 22 hp briggs stratton take
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 16 hp v twin..replaced con rod and piston
Needle and seat not functioning ... float stuck or trash in needle and seat of carb.
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
May 18, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
749 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
