Question about John Deere 22 In. Rear Tire Chains
Need wiring diagram for starter on a 1999 or 2000 johnson ocean pro outboard
  • tunalicious Jun 01, 2010
    If it were that simple I wouldn't need help. There are 4 black wires. 3 red wires, and one yellow. The statter is sitting verticle with the gear on top. Small yellow and small black are on two little post on the bottom/oppositeend of the gear. Large red and two smaller red wires all to side/horizontal large copper post. I have 2 smaller black wires on one mounting bolt, and the larger on the other mounting bolt.
    Turn the key and i can hear the gear running, but not enguaging the fly wheel.
    I have tried two good statrers and both are experiencing the same problem.
    Do you have a wiring diagram for a 99 or 2000 150 hp johnson ocean pro? Or an experienced outboard mechanical answer.
  • tunalicious Jun 02, 2010
    I need an marine mechanic with expertise on outboard motors not someone to research finding a repair manual. I want to know how to wire my starter from an expert.
  • 2,418 Answers
I am working on a picture for you. But seeing your comments I do not think your problem is related to a wiring issue. This type of starter is a centrifugal engagement. I will send a picture if you think it will help. As the starter spins it pushed out the small gear to engage the flywheel. If 2 other starters have done the same thing I would think something is out of adjustment, meaning the starter mount. If the starter gear cant engage the flywheel some thing is keeping it from spinning out. Do you have a good hot battery? Can you see the starter as it turns, it is reaching the flywheel? Check this and repost with what you see.
Posted on Jun 02, 2010
  • 4 more comments
    Mount is perfect it will only go in one way. My battery is fairly new, worked fine two days ago. I will try another good battery because is is an easy test. The starter spins when I turn the key, but sounds to weak to pop up. I even tried it with a rolling charger on quick start connected to the battery. With so many wires I keep thinking one is out of place. that's why I was hoping to be conversing with an outboard mechanic who has access to the manual with diagram.
  • John Fourteen Six Jun 02, 2010
    One way to test the starter is with a set of jumper cables. Hook them to a battery, the black to a ground on any metal part of the engine, then with the red or positive cable touch the post at the small yellow wire you see on the bottom solenoid. It may will throw sparks so watch for any fuel or flammable stuff. The starter should pump out the small gear on top it may not turn if you do not have the main red wire hooked up. The small yellow and black wires are the solenoid that causes the starter to engage the flywheel. The black are ground wires, the yellow is hot from a switch or key switch.
    I can get a picture but it is not great. --
    I tried the jump to the yellow but it does the same thing as turning the key. Gear spins but not enguaging the fly wheel. Tried jumping starting battery to a new deep cycle battery with same results. I have a tough one here. I see you are on the right track and know what starter Im dealing with. A diagram from an authorized omc mechanic may be my only solution.
    Here see if this helps ----------
    Next would be to spray a little wd 40 or graphite on the starter gear shaft. Thats all I got, Be sure all your connections are good and tight, all clean, battery hot, grounds good and tight and clean..
  • 313 Answers
I found a site that you can purchase the Repair Manual that has the wiring diagram in it. I have not been able to find the diagram for that year anywhere so far. Here is the link to get to the manual I hope this helps you. Randy FixYa Support Team
Posted on Jun 01, 2010
  • 3,083 Answers
I found one original service manual that had been sold on Ebay. Here is the link to that site: http://forums.iboats.com/showthread.php?t=283812
Go there, and find the person named "HybridMX6"- he's the one that bought the manual. If you join the site (it's free), you might be able to message him through it and see if he will be kind enough to make you copy. That's the best lead I have, but I will keep looking. As you know, it's not going to be easy unless you just happen to find an owner, but it's worth a shot. Good luck, hope this helps!
My 2001 johnson 150hp ocean pro outboard starts and runs for a minute then shuts off. Help!
low water flow/pressure, low oil level
crank position sensor or blocked main jets in the carby , low fuel supply
Jul 02, 2017 | Ocean Boating
Need wiring Diagram for 60 60hp Johnson Outboard motor
Google outboard engine wiring color codes
Sep 06, 2014 | Boating
Wiring schematic manual
Check here,
http://www.kicksup.com/evinrude/
Aug 15, 2014 | Johnson Evinrude Starter-Outboard 97 V4-V6...
50hp johnson outboard
Look on thin red wire that leads from starter solenoid,holder is normally situated on top of cylinder head
Dec 15, 2013 | Boating
Wiring diagram johnson outboard 1993
friend. .take it to the shop it will drive you to drinking trying to figure it out they can have it fixed way before you can figure out whats wrong and it will cost you more for them to fix what you broke
Oct 08, 2013 | Boating
Johnson 6hp outboard engine fuel pump diagram
Here is where you can get a service manual, they have a lot of info you might need...
Johnson Evinrude Manuals 1917 2007
Jun 11, 2012 | Johnson Boating
Starter motor on 130hp Johnson outboard won't
does it turn or can you hear a click as you try ? if its not turning check the starter brushes and if it clicks then replace solinoide !
Apr 04, 2012 | Yamaha Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Looking for a starter solenoid wiring diagram
save yourself some money and go get a lawn mower solenoid and find a way to mount it yourself. I have done a johnson outboard and a tigershark jet ski this way with no problems.
Jun 18, 2009 | Boating
John Deere 22 In. Rear Tire Chains Logo
558 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
