Question about Reddy Heater-30-55,000 BTU Variable
Vogelzang kerosene heater will not ignite (no spark)
I have a Vogelzang kerosene heater that will not produce spark. The model is American Salamander 155. The unit powers on when plugged in and then trips the breaker after about 5 seconds, due to the safety features. The fuel is atomizing well, fan runs great but just no spark. Looking for any info to troubleshoot or check the different components. I don't know if it is the circuit board, ignition transformer, or other small transformer? I am getting 120v to the ignition transformer.
Any info?
Thanks!
    Habit-Forming:
    New Friend:
  • 117 Answers
If it's tripping the breaker that means some wire is grounded .Check all safety wire to make sure they are not exposed and touching the unit frame .
Just follow the sequence of operation and you should find the problem
Posted on May 19, 2017
    Top Expert:
  • Reddy Master
  • 79,186 Answers
There is an igniter module and then the igniter electrodes (check the air gap) that produces the spark to start the fuel burning, both could be defective.
Posted on May 18, 2017
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a American 155 Forced Air Kerorsene heat
Here is a tip that will help you to figure out what is going on there..
http://www.fixya.com/support/r3818299-reddy_heater_troubleshooting_torpedo
heatman101
Posted on Apr 21, 2010
I just bought a remington 45,000 btu salamander. It heats great. although I'm going to have to exchange it because there is a short in the power plug. My question is : is there an additive available to...
i know you can buy kerosene additives to make it smell better.... they are liquid that you mix with the kerosene... but i'm just not sure exactly where to get it.... try like lowes, or home depot, or tractor supply co...... look around anywhere places sell kerosene heaters
Dec 26, 2010 | Desa International (R165DT) Utility Heater
Can a Kerosene leak outside be dangerous?
It could be a fire hazard and if enough leaks into the ground the EPA could get involved. Probably a lot cheaper to fix it.
Mar 16, 2010 | Milwaukee Tool Master Heater 70,000 BTU...
R.H. 40,000 kerosene/diesel salamander: sprays,ignites,blows 10 s
You said the fan blows but does it light? Diesel may have gummed up the nozzle or pump or fuel line.
Jan 30, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Not much heat output, and fumey model BY100CEA
Check the nozzle, if it is dirty you can get a stream instead of a spray and the fuel won't burn completely.dI would also make sure the blower wheel or fan is supplying enough air for compustion.
Jan 26, 2010 | Milwaukee Tool Master Heater 70,000 BTU...
No fuel to my torpedo heater
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Apr 02, 2009 | Milwaukee Tool Master Heater 70,000 BTU...
Pro-Temp forced air kerosene heater
my heater had a filter made out of copper that looked like a bubble stone for a fish tank. I forced compressed air through it and put it back together and it worked great
Jan 15, 2009 | Heating & Cooling
Readyheater starting problem
air compressor needs to put out between 3.0 and 3.5 psi of air for proper suction across the nozzle - the nozzle acts as a venturi to create suction or a vacuum.
Mar 07, 2008 | Heating & Cooling
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater-30-55,000 BTU Variable Logo
1,343 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
