Question about Intel DG31PR Motherboard
It won't start
My computer doesn't start normally
    Problem Solver:
  • 7 Answers
First clean the part of your computer then remove all the cords that put into the back of the computer then after cleaning and blow put it again...
Posted on Jun 02, 2010
Ibuypower won't boot
Unplug the computer, Hold down the power button for 5 seconds.
Plug the computer in. Power on the computer.
Call, text or email Shane 801.554.4142 / rsownbey@msn.com
Apr 27, 2013 | Computers & Internet
My 1991 Ford Tempo won't start. It turns over but doesn't spark. The battery has been replace, checked fuel pump and spark plugs but it still won't turn on. Help?
change the ignition pick up coil assembly normally located on the distributor under the rotor on the bottom of the distributor or just replace the distributor
Jan 30, 2013 | 1991 Ford Tempo 4 Door
My 2005 xb won't start and when you put your foot on the brake it is tight and won't move
The tightness of the brake is normal. as the servo doesn't work until you run the engine. It could still be the battery as the radio only takes a small amount of power, whereas the rngine needs a lot more, get it checked by an electrician.
May 19, 2012 | 2005 Scion xB
GMC 2000 sierra pick up 1500 sounds like it wants to start but won't turn over. Battery sounds good so I guess battery and alternator are ok. For several years fuel gauge doesn't work and...
It sure could be. But, first...by "won't turn over" you do mean it cranks at normal speed but won't start?
A simple test of the fuel pump is to stand by tank and listen as someone turns key to on. When first turned to on, your pump will activate for 2 or 3 seconds, pressurizing the fuel system, and then shut off if the engine computer doesn't get a cranking signal. Do you hear it come on? If not, then something's not turning your pump on. If you can hear it buzz on briefly, then maybe it's your filter. Another test: Spray a little starting fluid into your intake manifold (remove the big hose going into intake manifold) while someone tries starting it.If it doesn't fire and try to stay running, then it's probably an ignition problem. But if it does fire off, then you know it's a fuel problem-likely your pump or filter. good luck.
Nov 07, 2011 | 2000 GMC Sierra
My x5 3.0i 2006 t won't start this morning but temperature, gas level clock were wrong so I turn the engine off and restart a couple times it won't start and I saw message trans. false safe...
no. I'd suggest to disconnect a battery for 15 mins, reconnect, wait for 5 mins and try to restart. If it doesn't help (sometimes there's a program block to prevent stealing equipment) call a dealer
Aug 04, 2017 | 2003 BMW 5 Series
Good Day! i have a aspire 6930. I've had it for a
The average life of a laptop is 5 years. Your model was made in 2008. Replace it.
Mar 01, 2017 | Acer Aspire 6930-6455 Notebook
2008 impala will not start ,when trying to start service traction control light comes on
Does it crank over normal and just won't start or does it seem to turn over slowly or not at all. If it doesn't crank over like normal, test your battery. Low voltage will do strange things.
May 20, 2011 | 2008 Chevrolet Impala
Intel DG31PR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
