Question about SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television
TV stuck in Monochrome on the S-video input selection
When selecting the S-video input, it is stuck in monochrome. When the small center box appears indicating the input, the S-video reads monochrome at the bottom, and I cannot find a way to change it. I have also lost the user manual. This is a recent problem, and I have had this TV for a few years.
Thanks
S-video input is stuck in monochrome- when the small center box appears allowing you to change the input, the S-video box reads monochrome at the bottom. I cannot find a way to change this and have misplaced my user's manual. Help!
Thanks-
jg
Posted on Oct 21, 2008
I have a Nikkai S-VIDEO & STEREO PHONO to SCART connecting my tv to BOSE 321, yet the picture is coming through in monochrome. Should i have bought a different connector?
Monochrome means that the TV's input is set to composite and not S-video. This is common with Panasonic TVs. Have a look to see if there's an option to change the preference from composite to S-Video. That will sort the problem.
Sep 10, 2014 | Audio Players & Recorders
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
I just got a new player. Worked perfectly in the shop but brought it home and have a problem. After plugging it in it plays the DVD fine EXCEPT, the picture is in black and white. This was not a problem...
Select the type of video your TV requires within the menu of the DVD player and match it.
If the TV requires CVBS input and you are supplying S-Video, then you will get a monochrome picture because the chroma content is not being used.
Hope that helps.
Feb 27, 2011 | Televison & Video
I WANT TO BE ABLE TO CHOOSE TO PRINT IN COLOR OR PRINT ONLY IN BLACK & WHITE IS THERE ANYWAY TO DO THIS ON THE DELL 3115CN
Click Start
Click Control Panel
Click Printers
Right-mouse click the icon for your Dell printer
Click Properties
Switch from "colour" to "black" (or "monochrome" or "grey-scale")
Sep 30, 2010 | Office Equipment & Supplies
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Screen problems
Check TRC heater voltage (6,3 V., pins 3-4 of TRC socket counting counterclockwise) when picture goes off; if there's no voltage but it appears when picture comes back, look for bad solder joints tracing the circuit backwards to the power supply. Usually, the 6,3 V. tension comes from a single diode-electrolitic cap circuit at the secondary of the power supply transformer.or check this
Pin assignment for a monochrome 9-pin D connector are:
1, 2: Ground
3, 4, 5: not connected
6: intensity control (contrast)
7: video signal input
8: horizontal sync.
9: vertical sync.
Video monochrome cards usable are:MDA (monochrome display adapter) HGA (Hercules graphics adapter) -Some CGA (Color graphics adapter) and EGA (enhanced graphics adapter) cards that have a switch mono-color can also be used.
Jan 26, 2008 | ViewSonic G790 19" CRT Monitor
Zenith A25A23W tv - Powers up - Black screen, no sound
You might have a bad power supply inside you TV or even a couple of dry joints. Patrick
Aug 26, 2007 | Zenith A25A23W 25" TV
SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television Logo
Top SVA-USA Televison & Video Experts
Henry  Thomas
Henry Thomas
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
