Question about Panasonic NN-H504WF Microwave Oven
Where can I buy light bulbs (120V/30W) (part F612E5H01AP) in the Toronto Area - I actually live in Pickering.
    Genius:
  • 1,416 Answers
the closest place to you is Accufix Appliance Service 29 Skyridge Road, Toronto, ON M1E 4N7, Canada (416) 283-7447
Thank you and thanks for using fixya.
Posted on Jun 01, 2010
When the microwave is cooking the light inside dims. When done cooking the light returns to full brightness. Is that normal or is there a problem with the microwave?
I've seen this with most microwave ovens I've had. When the microwave emitter kicks in to cook, the unit uses much more power, providing less to the internal bulb, which dims a bit. Unless it's very dramatic, for example the bulb turning off or going almost out, it's normal behavior. If the bulb is going very dim or out, it could be that the circuit it's connected to isn't providing enough amperage to adequately run the oven. In the case of your microwave, it's rated at 15 amps, so should have adequate power on a standard household circuit by itself.
Apr 09, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
30W/125V microwave replacement light bulbs
Try to get the bulb number off one of them (usually printed on them) and Google for a source in your area.
Dec 02, 2012 | Microwave Ovens
Kenmore elite microwave convection 721.67903 light bulb
27oct: BKOK, replacing the light bulb is not simple, and requires a T15 security bit. Our microwave bulb blew this week, and sears on-line was not helpful, so I took the cover off and removed the bulb and the filament is blown. Here is what you need to do. Sorry, it's not easy. 1) remove the cover - this has 3 standard black phillips head screws, 2 on one side and 1 on the other. Then, there are 4 standard silver phillips heads on the back, plus two size 15 Torx screws that require a security bit to remove. 2) remove the 3 sided cover by prying the bottom and then pushing the cover towards the back of the unit to remove the latch keeping the cover secure to the front of the machine. 3) Now, there is a wiring diagram on the cover, use this to locate the bulb, but I will tell you it is on the top of the unit near the control panel. The white plastic connector has 4 wires going into it... Red, Yellow, Brown and Black. The bulb is secured with one screw and permanently attached to a trapazoidal base. The markings on my bulb say KEI, Korea, 125V,30W. 4) Remove the screw and lift the bulb assembly out and see if the filament is blown. The bulb is clear and so it's easy to see the filament. 5) I'm gonna go to local repair shop to see if they have replacements, but I usually go to AppliancePartsPro. They do have this bulb listed for under $5. , which is ok, but I hate paying shipping on such a small piece. Maybe I'll buy some other stuff. Good luck, it's not easy, and not a easy do-it-yourself bulb replacement. But if you are mechanically and electrically competant, it's not bad. But seriously, this is a lot of work to replace a light bulb. I'll take a picture and post that as well
Jul 05, 2012 | Kenmore Microwave Ovens
Ge jvm1790wk convection/microwave oven exterior light bulb burned out...I can't read volts and watts on the original bulb and don't find the information in the manual, what do I buy to replace it?
The cooktop light is 120V, 40W max., part number WB08X10051.
That's all covered on page 27 of your owner's manual here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven or part numbers here.
To replace the inside light, you'd need to remove the oven from the wall, and take off the outer cover.
Jul 08, 2011 | GE JVM1790 Convection / Microwave Oven
Hi, I need to know which light bulb to buy for my old Sanyo Miocrowave oven. It is Model: EM-2500-LA, Serial: V53510658, Year of purchase: 1985.
Hi and welcome to FixYa, I am Kelly,
The part number for the 20W light bulb is 4612S16400. It has been discontinued and is no longer available no matter where I have checked. I started my search for your bulb 2 minutes after you posted your question. You may be able to carry the bulb into a LOCAL appliance parts supply store front and find a suitable alternative. Do not install anything larger than 30 W but you can use anything from 15 - 30W as long as the bulb will fit in the socket.
PAC Parts is the primary source for Sanyo parts and you can see the result I got there:
http://www.pacparts.com/part.cfm?CFID=5866672&CFTOKEN=11657601
Repair Clinic Same result
Union Electronic Distributors
http://www.ued.net/ued/addItems.do?itemCode=SFS4612S16400
I wish I had better news but this result is what the results of an after market search have revealed.
If your good with appliance repairs here are some alternatives: (Only first 5 entries)
http://shop.ebay.com/i.html?_kw=Microwave&_kw=bulb&_kw=20W
Thanks for choosing FixYa.
Kelly
Apr 08, 2011 | Sanyo Microwave Ovens
Dear Sir, I have an electrically
Yes should be okay to work without bulb without any modification......Try Philips lighting agent for your 120 volt lamp...
Feb 17, 2011 | Microwave Ovens
What type of replacement quartz bulbs for the under counter lights?
could be 10watt or 20 watt i for under counter lighting. If too high could burn out low voltage transformer assuming its low voltage....12 volt...
Apr 08, 2010 | GE JVM2070 Microwave Oven
Interior Light GE Advantium replacement
Yes, that's right. Very common, standard 10W halogen available about anywhere. GE's # is WB36X10163 or WB36X10177.
Jul 18, 2008 | GE Advantium 120 Convection/Microwave Oven
Panasonic NN-H504WF Microwave Oven Logo
434 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
