Question about Bosch 24 in. SGS66E02 Exxcel Built-in Dishwasher
Hi my names is ryan and my dish washer i not talking all the tabs down the spring did come off the slide thing were i put the tabs can u help me
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
Electrolux EIDW6305GS1 will not run , keeps flashing error code 11 which indicates drain valve problem. I have replaced drain valve, wash pump, float valve and reed switch but no luck, still flashin
Hello Gene Skates - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. This is typically not a DIY job and strongly recommend contacting a professional to check the wiring between the main control board and drain valve since you have already replaced the drain valve.
Jan 11, 2013 | Electrolux Frigidaire Professional Series...
Electrolux dishwasher with error code 11
Hello Jason Johnson - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting a professional to check the wiring between the main control board and drain valve.
Dec 30, 2012 | Electrolux Frigidaire Professional Series...
Error code 11 on electrolux wave dishwasher
Hello - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting the technician that repaired your unit previously to check the wiring between the main control board and drain valve. Some certified technicians warranty their labor and part for 30 days.
Nov 04, 2012 | Washing Machines
How to put steering wheel back on
Are you talking about the spring and C-clip that go on the steering shaft UNDER the steering wheel? There is a special tool required to do that. However, I MADE a tool to accomplish this task by using a short piece of electrical conduit that was jus large enough in diameter to slide down over the steering shaft. (I think it is 5/8" conduit - can't get to my tool box right now to check) Anyway, measure the diistance from the end of the shaft to the groove where the C-clip snaps in. Cut a piece of conduit to this length. Then put your spring on and slide the C-clip on as far as you can by hand. Then put the piece of conduit over the shaft so it is contacting the the C-clip. Then use a flat-washer on top of the conduit and insert your steering wheel fastening bolt into the washer/conduit apparatus and screw it into the shaft. The bolt and washer will push the conduit, which will force the C-clip to slide down the shaft and compress the spring. When you screw it far enough, you will hear the C-clip "Click" into the groove. Voila! your spring and C-clip is installed. Unscrew the bolt and remove the conduit and washer, then assemble the rest of your steering column/steering wheel components.
Dec 24, 2011 | 1995 Ford F150 Styleside Regular Cab
Bought a new TV now the remote won't talk to the sat box
Hi mgreaper my name is Mike Houston of DISH Network there is a way toprogram your DISH Network remote to your new TV. What you can do is what wecall a "power scan" and it finds the code for your TV to our DISH Networkremote, The first thing you want to do is hold down the clear TV button for 6seconds and then push and release the big red Power button and press andrelease the Channel Up button until the TV turns off and then stop. Then youwill want to press the # button and press the red TV button and make sure yourvolume and mute are working. I will send a link to help with the Power Scan. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Feb 05, 2011 | DISH Network IR Remote Control
My dish washer has a f1 code i put to much
f1 code indicates a leak.open bottom drawer,find the spring clips on side of tub where tub meets the front panel.push the clip and you will be able to slide the track back and remove tub. put tub on floor to left you should see a puddle,dry it up should be ok. Sensor is sensitive to moisture allow 24 hrs to reset if all visible water has been dried up. hope this helps ,please rate my solution :)
Jun 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I replace the drum gasket at the rear of Model 97273100.
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
Jun 16, 2009 | Washing Machines
Need name for part in Disc Hub for ordering
is that the automatic hub ? ... if so leave your email address i'll send you the diagram for it.
May 25, 2009 | 1987 Toyota 4Runner
Lost roller on Savvy
need more info spring and washer don't tell me anything.do you have all the parts.i think your talking about the spring washer that keeps the brush roller from locking up.if thats what your talking about remove the bearing cap off the end of the roller brush.lay it inside the roller concave ppart of the washer down put the cap back on.if both washers came out of thesame side put the spring washer in first then the flat washer
Aug 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Bosch 24 in. SGS66E02 Exxcel Built-in Dishwasher Logo
73 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
