No picture and no fan led light and the blue bar light both blink fast. after about 15 seconds everything shuts off
  • butjimz Jun 01, 2010
    Is there any way to confirm the solution he recommends. Can this be caused by an external factor, like DISH DVR going out because they both went out at the same time.
  • 11,800 Answers
Severe failure in the power source board. The tv must be opened and tested, this requires at least basic knowledge of electronics. I think it's time to call the repairman, and be prepared for a hefty tag at the end, this kind of failures are always expensive.
Posted on Jun 01, 2010
    Could this be caused by the DISH DVR going out or the reverse?
  • Azrael SRL Jun 01, 2010
    Yes, if it has been a short somewhere in a device then the high tension pulse generated could have easily fried the other device. In your case i think it was the dish that actually fried the tv, they are easily damaged by even very far away lightning strikes.
  • 10,865 Answers
Hello. It is most likely the y-drive(sus) board.The only problem is that this board usually fails when the horz.buffer ic's fail,which is usually part of the plasma display.This was a common problem with this set.The best bet is to find a new set,since the parts alone will exceed the cost of a new one.
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Why doesn't my neotv netgear remote no longer communicating with box?
What do the different Remote control front LED lights mean?
  • Blink blue color twice per second: Remote control has paired NeoTV PRIME and is trying to connect NeoTV PRIME.
  • Blink blue color once per second: Remote control is trying to pair the NeoTV PRIME.
  • Orange blinking: Remote control battery is low. Please replace a new set of AAA battery.
go to page 15 of the following document:
http://www.netgear.com/landing/stream/img/gtv-specs/GTV100_IG_25Oct2012.pdf
Sep 09, 2014 | Computers & Internet
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
Car starts but shuts off after 15 seconds
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Feb 10, 2010 | Omega MARS-22 Remote Vehicle Starter with...
HP Pavilion dv6225us won't boot (power not the issue)
Check http://www.fixya.com/support/t3440299-presario_f500_laptop_problem
Nov 16, 2009 | HP Pavilion dv6225us Entertainment -...
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
