Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Fisher and paykel doulble drawer dishwasher gives me an f1 repair symble and will not turn off. Fliped breaker hoping for a re-set. Not a freaking chanse. What can I do?
  • Fisher and P... Master
  • 713 Answers
Hi john. F1 means your machine has activated the flood switch. you either have a leak or you might have used the wrong detergent causing it to soap up and the suds escaping out thru the overflow. let the machine sit turned off for a day or so to let it dry then try the top drawer first. if that goes alright then try the bottom drawer.if you need more help please reply.also reply if you still have F1 coming up.
Posted on Jun 02, 2010
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher beeping and displaying F1 on screen. HELP!!
F1 error means that the flood switch has been activated. To reset the flood switch you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Once the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position.
Mar 17, 2011 | Fisher and Paykel 23 in. DS603H W Built-in...
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher & Paykel M#DD603SS - While not running F1 repair mssg
Actually the part is called a Link Actuator. There is one for the upper drawer and one for the lower. When the drawer is shut, it will actuate and the dishwasher will lift the drawer up against the upper lid. When the actuator is broken, this will trigger the flood switch which inturn triggers the F1 code. In the meantime, when the dishwasher is turned on, the water will shoot over the side walls of the drawer and get down below to damage the terminal block module.
Jun 21, 2009 | Fisher and Paykel DD605SS Stainless Steel...
TOP DRAWER WAS NOT DRAINING..NOW THE F1 ON BOTH DRAWERS IS ON
F1 code indicates a leak,you will find the water under bottom drawer.Lid probably not sealing well.
Jun 17, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Dec 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
360 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
