Question about Keurig B70 Coffee Maker
My kerurig b77 shuts off after one or two cups of coffee, when water level is low blinking lights come on then when i fill it up and make a new cup of coffee it shuts off. it does'n't do this all the time it is less than one year old
    Problem Solver:
  • 5 Answers
Has to do with the water tank seal -- see here on how to work around the problem:
http://www.nate-lewis.com/blog/?p=288
Posted on Jun 05, 2010
How do you make coffee with Mr. Coffee, Jr. 4-cup automatic coffee pot?
Its pretty easy to open the top and fill the reservoir with water up to the level needed (i.e. 4 cups). Then press the ON button to start the brewing process. Make sure you fill the filter with ground coffee.
See the following link:
Mr Coffee Coffemaker
Apr 13, 2015 | Coffee Makers & Espresso Machines
Brewer not filling complete cup, then fill water and small cup lights blinking at same time continuously
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
May 14, 2011 | Keurig Elite B40 Coffee Maker
Coffee to water
The Instruction Manual for the West Bend Coffeemaker can be found here:
http://www.westbend.com/supportdata/L5590A_Coffeemakers_ALL.pdf
See page 4 for amount of coffee to use.
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
Mar 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
Orange needle cover has come off my krurig coffee maker and will not stay in place when making a cup of coffee it ends up in your cup of coffee
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Jan 28, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Keurig B70 Coffee Maker Logo
372 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
