Is there a particular XP installatiion procedure that ensures a complete wipe of the hard drive (no viruses)? I know there used to be something called fdisk but don't know if there still is.
  • roncink Jun 01, 2010
    yes, i hope so, thanks
  • 6,993 Answers
yes, there is still fdisk, but you need a startup disk to be able to use fdisk. fdisk is a command and you need to know to use command prompt to be able to use fdisk.
Also, you can wipe of your hard drive in the process of installing windows xp. While installing the windows, you will first get to an option where you will be asked to save the files on our hard drive, choose don't save, and secondly, you will see an option where you will be asked to format your hard drive, once you select the formatting option, all the files on your hard drive will be completely wiped off and new xp files will be installed.
So, its not necessary to use fdisk, installing windows xp will also wipe off the files on your hard drive because there will be an option where you will be asked to format the hard disk and once this is done, the hard drive will be wiped off.
Take care
Posted on Jun 01, 2010
How to reinstall operating sistem after use of wipe drive
If you used a wipe drive and now you have a completely erased hard disk ..you need a boot-able disk with the operation system you want ..and the procedure is to set from bios the cd /dvd drive as first boot device ..save settings and restart with the boot-able disk inside..It will ask you to press a key for to confirm the boot from the disk ..and after that will start loading files..
For windows xp ..the procedure will take more human interventions ..to sign the agreement and select the partition ..(format it clean when it is the case ) ..and start the windows files loading ..It will restart a few times ..and will need to be let alone and do not press the key for boot from cd ..cause this way you will run it over from the start ..
For windows 7 and vista things are more relaxed..cause it will only need to select the partition and format it first ..and after that will no longer need much intervention til the end when you select user name and time zone..
If your computer supports the boot from usb flash drive ..it is more easier to install windows 7 from this stool ..All you need is to download a good windows image from a torrent site ..and after that download windows 7 to DVD tool from the internet ..and use it to make a boot-able usb flash ...or disk ..
For windows xp you have to download an image file and burn it using a image burner so that you wil have a boot-able disk ..(Use Nero if anything else fails ..I always burned windows xp with NERO )
let me know if you need links for images ..or try search on pirate bay ..or something like that .
Nov 10, 2010 | Toshiba Satellite M45-S331 Notebook
I am using Windows XP I tried to reinstall the operating systems and now have it twice under the one partition, how do i delete one of the windows installation to reformat the hard drive?
Its going to be a case of re-installing XP again.
As you go through the process, XP asks you which partition you would like to install onto.
If there's already and installation on the partition, you have to delete that partition.
As you continue through the process, XP will has you if you what kind of file system do you want Fat32 or NFTS. Choose NFTS and go for the full format. That should clear the drive of previous installatiions
Apr 30, 2010 | Microsoft Windows XP Home Edition
Virus
Try these below.
Step 1
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
77f4fd8.jpg 2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
OR
Step 2
Restore factory settings Acer.
______________________________
Ensure all Data is backed up, all data will be deleted.
2 Please also ensure that all USB storage devices are removed before starting the recovery process
3 Restart machine
4 When your unit switches back on, wait for the ACER screen then hold down alt & tap f10 repeatedly..
5 Please wait a moment until prompted, -How would you like to restore?-
6 Please select –Restore system to factory default-
7 Enter your defined password or enter six zeros ‘000000’
8 Click ok
9 Please wait until process completed, this will take 45min – 1hour
ALL personal information on the C: Drive I.E photos, programs, music and documents will be wiped when the above steps are taken. Files located on the D: Drive will be safe from the procedure.
After these if you face the same problem then format the OS,because virus damaged your OS.So, you must install the OS again.Thanks & waiting for your feedback.
Mar 19, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
No internet connection
wipe the hard drive clean and reinstall windows.
only thing you can do is reinstall operating system.
If you do not know how to do this, take computer to someone who does.
If this is something you do not know how to do, it is too difficult to explain to you how to do in this forum without knowing all your hardware specifics.
Feb 24, 2010 | Toshiba MK8025GAS 80 GB Hard Drive
I need the bios and flash program for a gateway 4535gz I suspect it has a bios virus because a fresh install of windows XP pro and symantec anti virus and drivers (all freshly downloaded) becomes corrupted...
There is no such thing as a BIOS virus. However, there are such things are boot sector viruses. Before you reinstall XP again, wipe the hard drive completely by deleting and recreating the primary partition.
Dec 17, 2009 | Gateway 4535GZ Notebook
I loaded a new, Windows XP formatted IDE in a 570e-then nothing
Well the formatting must have been different! try dropping the partition and format using the pc you are installing it on
Sep 07, 2009 | IBM ThinkPad 570E Notebook
Windows XP OS installation
its not a virus as when you format your hard drive it would wipe it out ... how many hard drive do you have ? if you have 2 install a new instalation to the good hard drive and you should get to the part of xp that says do you want to format the partition on this hard drive by pressing ( f ) do this and when your pc has finished re-installing you can click on my computer in your start menu then right click on the bad hard drive and run a full format from there ...
hope this helps ... jedi-inc ....
Feb 09, 2009 | Microsoft Windows XP Professional
Hard drive wiped out
may be your hard drive has a bad sector.
Dec 07, 2008 | Computers & Internet
I got a virsus wiped my computer but im not sure if i have done it properly. So i need help with wiping it 100%
use an updated virus remover like AVG or Symentec with updated virus defination file. check complete system.
Nov 29, 2008 | Acer Computers & Internet
Reformat
Insert the winxp disk and boot from that, when prompted hit any key to boot from cd.
Win xp will start to install choose to delete the partition, confirm delete.
then press enter to install to that unallocated partition, choose format to NTFS.
Follow the prompts and it has formated the hard drive and will install XP.
Apr 30, 2008 | Dell Inspiron 8500 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
