Question about Concord Fans (52PMB5WH) Ceiling
This fan has three speeds, but it's operating only in the fastest speed. What is the fix? Thanks.
May car is heating above 100 from two or three points i am in saudi arabia
Find new mechanic and insure fan is really operating properly. Also might try using one of the many coolants that cool better than just anti-freeze and water mix. May have to add extra oil cooler also.
Jun 10, 2015 | 2008 GMC Acadia
Hi, I have an aloha 3 speed oscillating pedastal fan. motor is almost seized. can it be fixed?
What is the estimate rotation rpm at fastest speed ? Normally pedestral fan is a 6 poles or 4 poles single phase motor?
Jun 08, 2012 | Aloha Housewares Dryers
Re: Hunter Fan Model 27185 - 060 The above fan was purchased circia 5/1/2000 and does not now function properly (actually it has not been fully working for 4-5 years. It is installed in a 19' ceiing...
You either have a wiring problem possibly a ground rocked loose or the motor is going out.but if you press 1 while its running and it dies sounds like motor and nothing wrong with remote
Apr 26, 2017 | Hunter Heating & Cooling
When the Casablanca fan remote control wall button is pushed the fan beeps and progresses to the fastest fan speed and stays there. How do I adjust the fan to be able to vary the fan speed so I don't have...
the button may get stuck or the sensor may be off.... also it could be that the setting is backwards on the fan to start on the fastest and end on the slowest
Dec 01, 2010 | Casablanca Fan Dryers
I have a ceiling fan with remote, remote will not turn fan on high, how can i fix this
The fan probably has manual pullcord switches - one for the light and the other for fan on/off/speed. The fan control pullcord needs to be at maximum setting.
Switch the fan on using the remote. Then set it to high using remote.
Now use the pullcord switch (probably cycles through off, low, medium, high, off with each pull). Set it at its fastest speed, and leave it there.
You should now be able to select highest speed from the remote.
Happy to try to help more if that does not work.
Feb 25, 2010 | Hampton Bay 24750 Huntington III Ceiling...
WIndshield Wipers only start on fastest speed
There are three things involved in wiper operation, switch, the delay circuit board and the motor. If you select winshield wash do the wipers operate normaly? if this is the case then the motor works and delay is operating < not a guaranty on delay but it does say the circuit is operating.If wash cycle does not work then circuit not working< could still be switch causing this> if you know someone or you yourself can remove switch it needs to be ohmed to know that it is operating and if it is then voltage during operation in all settings needs checked at wiper motor.If no voltage found in inoperable settings then delay is not working.While investigating problems like this always inspect wiring as you check from point to point because could be damaged wires as well.
Apr 21, 2009 | 1999 Chevrolet Malibu
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Fan switch
black coloured wire is for common and for each and every speed three different colour one colour for each speed red for first speed yellow for second speed and blue for third speed
Jul 28, 2008 | Hampton Bay 24002 Ceiling Fan
Concord Fans (52PMB5WH) Ceiling Logo
Top Concord Fans Dryers Experts
jdthefixer
Tom Chichester
Ken B
Ken B
Are you a Concord Fans Dryer Expert? Answer questions, earn points and help others
