When turned on you view only a vertical line. i beleave a power surge caused this. what part or parts do i need to replace. mod no-ps35123. tnank you
  • 767 Answers
There is no vertical chip in this model/ ctc 169.
it's a transistor- resistor - cap circuit.
It's either the yoke wires on neck of the tube have
become de-soldered or the more likely possibility
is the viliot / white wire from the yoke have simply
become de-soldered if you first re-solder those two
wire chances are good you will restore full picturewhen turned on you view only a vertical line. i - repairtech99.jpg
Posted on Mar 17, 2011
    President:
  • 1,961 Answers
You need to change the vertical ic.It is a linear ic mounted with heatsink located near the plyback or resolder the components on the vertical section...tnx please rate my help
Posted on Jun 04, 2010
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
I HAVE A LC401EM2F EMERSON TV 2 YRS OLD. WHEN I TURN ON THE TV I INITIALLY GET GREEN VERTICAL LINES, AFTER IT HAS FOR BEEN ON FOR A FEW MINITUES, THE VERTICAL LINES DISAPPEAR BUT A HORIZONTAL LINE APPEARS...
It sounds like a power surge has damaged the color controller and scan line section of the circuit board. The cost to repair is more then the replacement cost. Next time use a UPS for protection (battery back up for computer and electronics). Regards DaytonComputerDoctor@hotmail.com
Dec 18, 2013 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Display vertical line
Turn off the monitor and disconnect it from the back of the pc. This way you will isolate the monitor from the PC. Now turn on the monitor, if you still see the vertical line then that means the screen is bad and you would need a new monitor.
If the monitor doesn't have the vertical line then that means your video card is the issue or if you have an integrated vga port on the back of the computer then the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Acer V173 Monitor
I got a vertical line on the left side of my lcd screen it is two vertical lines
Hi rexdale_davi ,
I would recommend you the below steps :-
  1. Check if the power cords are connected properly.
  2. If the product is under warranty , please get it replaced as it might have malfunctioned.
  3. The vertical lines usually appear because of bad panels which are caused due to power surges.
In many cases for larger TV's the cost to replace panel is found to be higher ,therefore people prefer to buy a new one, but i would suggest you to compare the panel rates and take a decision accordingly.
Hope this helps ..:)
May 11, 2011 | Computers & Internet
TOSHIBA 50" MOD.#50HP66 appears vertical
A part of the buffer memory from the image processor is faulty and all the data stored in there is corrupted, hence the lines you see.
What you must replace is the board on which the processor is situated, the logic one. Here it is
http://www.partstore.com/Part/Toshiba/Toshiba/50HP66/Toshiba/Toshiba/75003034/New.aspx
Feb 26, 2011 | Televison & Video
Colored "snow" vertical line an inch thick on Samsung plasma
That is the sustain and buffer boards. Try to find a repair shop to repair on the component/board level because the cost of new boards out weighs the replacement cost.
Best Regards,
Beach TV Repair
Jul 04, 2010 | Samsung PN50A450 50 in. Plasma HDTV
There was a power surge ,a black and then a blue line came on the screen,tv went off. when switch on a blue line appears, thanx
I assume by a blue line you are seeing a seeing a single line left to right across the screen. If this is the case it is a failure in the vertical deflection circuitry. There is no simple repair as a part or parts have failed. In the event of a "power surge" there could be a number of components affected. The unit would really need to be diagnosed by a competent technician. I have worked on many of this model and they are certainly repairable, but probably need two people to move it as they are very heavy as you know. I would get an estimate on the repair and make a decision based on that.
Nov 16, 2009 | Samsung TXR3079 TV
Pedro
Good Day, junop;
It could be one of these:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH. back.gif
Aug 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
You first need to rplace the outlet if it sparks where the surge protector is plugged in as it should not spark for any reason. then you need to make sure thast its not the outlet causing your problem by running an long extensition corn or moving the set to a differant outlet.
Sep 11, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
