Question about Philips Televison & Video
When I press the on button on my remote for my Philips flatscreen TV, the red light just blinks and the picture does not come on
  • paul_smit629 Jun 01, 2010
    Thanks for your help.
  • Philips Master
  • 11,800 Answers
The led blinks to notify you that there's a major fault in the power source, at least some electrolytic capacitors have failed. The tv must be opened and tested to determine more precisely what is the cause. This requires at least basic knowledge of electronics. I think it's time to call the repairman.
Posted on Jun 01, 2010
  • Azrael SRL Jun 01, 2010
    Sorry to disappoint you, this isn't a software error or a bad command that has froze the tv, an actual, physical part has failed and must be replaced.
  • Philips Master
  • 5,138 Answers
Have you Checked for bad capacitors on power supply board they will be swollen,vented or puffed up on Top 220uf 10v, 330uf 10v, 1,000uf16v also resolder your boards they are well known for Poor solder connetions Also what is your model number printed on back of TV?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Assuming this to be a LCD TV, blinking light means that the power is getting to the unit however, as its not working which means that the power board should be checked. To start with open the back of the unit and then check the power supply board for any bad (bulged/swollen) capacitors. Power supply board is the board where all the power cords/plugs goes into. After you have checked that also check the main board and if you can use a multimeter to test the components on these boards. All this should only be done if you have knowledge of internal circuitry of the unit as the components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
I have a philips universalremote controlcode for
The codes are, 007,107,516,608,618,718,807,901..Turn the TV on, aim the remote at the TV,press and hold the CODE SEARCH button until the light turns red, press TV, the light will blink once and stay on,enter one of the three digit codes, the light will go off, if not, you will need to try another code until it does, press the POWER button, the TV should turn off....hope this was helpful...
Apr 20, 2010 | Philips PM3S Remote Control
Need help programming philips universal remote for a sanyo tv
Here are the codes,0506,0311,0612,0002,0428,0802,0412,0619...Turn TV on. Aim the remote at the TV,Press and hold CODE SEARCH button until light turns red, press TV, the light will blink once and remain on,enter one of the four digit codes, the light will go off, if the light flashes instead of turning off, you will need to try another code until it does, press the POWER button, the TV should turn off..... hope this was helpful...
Apr 18, 2010 | Philips Universal PH301S Remote Control
Need to how to set remote philips TV an DirecTv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
these steps will set up the first device and then to set up the second device just repeat the steps choosing the other device and the code for it.
CODES: for the tv: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0019,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
for the direct tv: 1049,1766,1767,1768,0622,0632,0629,0623,0576,0586,0616,0613,0630,0634,0636,0638,0641,0652,0653,0657,0659,0607,0619,0537,0538,0539
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Philips Magnavox Learning Universal Remote
I HAVE LOST THE MANAUAL FOR MY PHILIPS MAGNAVOX UNIVERSAL REMOTE
You don't need the whole manual for the Philips Magnavox remote fortunately.
If you want to reprogram it for the Apex TV, follow my directions exactly.
  1. Hold down the Code Search button (on the remote) until the light on it turns red and stays red.
  2. Let go of the Code Search button.
  3. Make sure to switch modes at this point to which device you want to program, I'm going to assume TV Mode since your post says "Apex TV." If you need help with Apex DVD codes, I can answer that one too :)
  4. As you Press the mode button and release it, the light should blink for a bit, so keep your eye on it because after it's done blinking it'll stay red.
  5. At this point the remote want's you to press a sequence of numbers also known as Code[s] or Code Entries. Either way these are what are in a table inside the manual that you lost.
  6. I'm going to give you two codes in case one doesn't work: 044 and 335 (one of those hopefully will work)
  7. If the code worked you'll know right away because the light will get mad and start blinking again, otherwise if it DID work, it'll just turn off (the light will anyway).
  8. That's it, I reccomend you test out your remote with the TV now and make it everything works. If something doesn't, try the other code. If it still doesn't work right, I'll give you some more codes.
Hope that helped,
-Cheers-
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
APEX 044
Mar 21, 2009 | Philips Televison & Video
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Oct 17, 2008 | Philips HDD065 MP3 Player
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Philips pm 335 universal control
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
May 21, 2008 | Philips PM3S Remote Control
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Philips universal remote codes for symphonics tv
Manually turn on the device you want to control
1. press and hold the CODE SEARCH button til the light stays on release the code search button
2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
(the red light will blink off after each time the channel up button is pressed )
4 Press the MUTE button to set the code
hope this helps
Nov 23, 2007 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
