Question about Gear Head Wireless Keyboard & Mouse 24GHZ Wireless Keyb/laser Mouse Keyboard, Mouse
My keep board just stopped working. What could be the problem?
  • 31 Answers
Reinstall the driver or remove any newly installed drivers that could be conflicting
Posted on Jun 01, 2010
The 3A fuse on the white wire keeps on failing. what could the reason be?
Most likely bad PC board.
The fuse stops damage such as fire, but the PC board probably needs to be replaced.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other causes might be wrong polarity on 120 volt outlet, use a circuit tester to make sure the hot, neutral and ground are correctly connected.
Jan 28, 2017 | Rheem Water Heaters
My tv is keep turning itself on and off and my remote has randomly stopped working, ive had the plug out the wall the past 6 hours nd no joy, any ideas? I've put new batteries in the remote 2
Sounds like a power board issue? Dry joints on the main board? Capacitors may have issues.? I would not go opening up the TV if you are not aware of the potential dangers.
Mar 25, 2015 | Luxor LE40WTUD-B 40 Plasma/LCD/TV Cart
How do I fix the drive motor?
You need a motor control board, shoot me a message as if I might have one in stock for you
Mar 09, 2015 | Exercise & Fitness
Why does my Logic tv keep freezing? The remote stops working, I can't turn over channels or use the volume control and sometimes get a green band across 1/2 the screen. Please Help!
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced.
Sep 07, 2014 | Televison & Video
Wiper motor will not stop
If installed control board was used, it may be defective. Also make sure installed board works with your exact year model.
Apr 03, 2014 | Oldsmobile Silhouette Cars & Trucks
I can not print at all. The printer monitor says CHECK INK U051 BLK COL. I tried to change Cartridge few times and push Stop/Reset button ,but it's not working.
1) cartridge out 2) take the board 3) washed under board 4) keep cartridge 5) turn off printer 6) turn on push stop/reset button for 30 sec
Aug 12, 2010 | Office Equipment & Supplies
Our Microwave keeps running and won't stop. It is
The fan you hear is probably the magnetron cooling fan and that, and the light, are probably both controlled by the electronics board that controls everything else. You might inquire online at Maytag or the Sears parts department to determine the cost of a replacement board but I suspect it will either not be available at all or cost 3/4 of a new microwave.
Jan 23, 2010 | Maytag MMV4205 Microwave Oven
I have fan#1 and Fan#2 message on screen.It won't allow me to get on to service mode.Both fans are working, replaced actuator board, nothing. I noticed power board is sending 205V DC, and actuator board...
Check to make sure that both fans stay turning.If one stops prematurely, replace the one that stops. If they do turn until shutdown then try jumping the Temperature Sensor on the Lamp Housing. If that stops it from shutting down, replace the Sensor. If not , there is a chance you have a Actuator Board or a Digital Board causing the problem.
Hope this helps,
Skyassoc
Jul 04, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Gear Head Wireless Keyboard & Mouse 24GHZ Wireless Keyb/laser Mouse Keyboard, Mouse  Logo
267 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
