Question about Nokia N97 Cell Phone
Nokia n97 wont powerup or except charge - Nokia N97 Cell Phone
  • gemoody Jun 01, 2010
    nokia n97 wont power up or charge this happened after loading a nz vodafone sim card fone does nothing at all
  • Nokia Master
  • 13,433 Answers
Hello
Remove the sim card, it might have been wrongly inserted.
Take out the battery for 5 minutes, then reinsert it and try turning it on, if noting happens try performing this reset
turn your phone off and simultaneously press these four buttons circled in red.
  • Caps shift
  • Space bar
  • Delete button
  • On button
You’ll know it’s worked when you see the initial set up screen, asking country of origin
If your phone is still completely dead, check that the charger is working and possibly try another one, or another battery, don't buy another, just try.
If the phone is still dead it is faulty and will require repairs from nokia, we can not fix this at home.
Let me know if you have any questions.
Posted on Jun 01, 2010
  • 1,284 Answers
Hi, your N97 won't power up but it charges, am i right?
If that be the case, it might be that your phone is infected with a virus which you have to flash in other to restore the phone or that the power up button is bad in which case you have to take to a phone tech to fix...
Take care
    no it wont charge this happened afta loading a nz vodafone sim card
  • Shehu Pro
    Shehu Pro Jun 01, 2010
    I think the phone operating system may get damaged as a result of the sim card, you better take to
    service center of nokia nearby, tell them to update the firmware and
    also format the phone memory , every thing will come back to normal.....
Nokia n97 charging solution
Hi If the USB Socket (usb board) found no damage the only thing is to apply jumper.So, you can contact nearest mobile repairing shop or follow this link N97 charging solution.Thanks for visiting fixya
Aug 20, 2012 | Nokia N97 Cell Phone
My nokia n97 is not charging its show not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 14, 2012 | Nokia N97 Cell Phone
CANNOT CHARGING MY NOKIA N97, THE INDICATOR LIGHT IS NOT BLINKING, ONLY DISPLAY NOKIA AND THEN OFF
Please check your battery, it might have already been damaged. My battery was already bloated, and hard to put the back cover when I encountered the same problem. You may also borrow a battery, from a friend just to verify it. Before checking the battery, I did some verification using a known good nokia charger from a friend, and still could not charge it.
P.S. I replaced my battery after using my N97 for more than 3 years.
Feb 05, 2011 | Nokia N97 Cell Phone
My Nokia N97 is charging but the light is blinking and not at a solid light. When i try opening it, i wont open. What can i do to fix it up?
Im not sure ... what you are describing is typically a battery issue. You may have to replace your battery to overcome this problem.
Thanks for using FixYa.com
Sep 29, 2010 | Nokia N97 Cell Phone
I have a Nokia N97 and want to unlock it from its network i was given a code and it wont work, can you help??
For the best unlock code for your Nokia model mobile,
you can try this site http://www.theunlockarena.com/nokia-n97/rs13wp9/
It has the step by step instructions and easy methods for unlocking your Nokia mobile phones.........
Aug 26, 2010 | Nokia N97 Cell Phone
Nokia N97 usb block has degraded to the point it wont charge unless balanced on an object. does anyone have a guide on how to replace the usb block connector and where i can get one? \r\n warrenty was...
well you will have to change the charging point and u can always do that at a phone repairs shop or take it to the company shop nearest to you for repairs and if you dont want to go tru that stree you can always charge your battery tru desktop charger , thnks .
Jun 15, 2010 | Nokia N97 Cell Phone
Hi my new n97 wont charge or turn on
I bought a brand new nokia phone N97 but it does not charge. What must I do?
May 31, 2010 | Nokia N97 Cell Phone
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Nokia N97  Cell Phone Logo
96 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
