Question about Lenovo L215p 21.5 Wide Screen Full HD LCD Monitor
I found some dust particles behind Lenovo L215p
I found some dust particles behind the lcd screen, i want to clean them, but that requires dis-assembly, and i want someone to show me how to do it, in video if possible. :)
  • hassanfadil Jun 02, 2010
    Well the monitors on the videos are somewhat similar to my monitor, but it is quite a hard job as i saw, thanx anyway man.
    @chiefmecha
    I decided to do as you said, it is quite risky, thanx man :)
    President:
  • 1,138 Answers
Hi!
here's the link to the video you are requesting..dis-assembly of the back cover.. you may find it hard to understand because of language barrier, however, the video will show you literally how to open the back cover of your monitor.
http://www.youtube.com/watch?v=Rg_ncaGo030&feature=related
Now here's a better video.. hope you enjoy and learn from watching it
http://www.youtube.com/watch?v=SZE_R8CPtM0&feature=related
If you find this video very helpful to you, would you be kind to rate this solution and give a vote on this help below..thanks..
Posted on Jun 01, 2010
  • 600 Answers
I think you better not try to dismantle your lcd, even if you have a manual or video instructions, you might have problems that may arise, for example not fitting it back again in proper fitment, maybe try using a vacuum cleaner fitter with a suction or something, i would not advise opening your lcd just to clean it, it would be a waste if you have done cleaning it but eventually ending up with a clean lcd but not functioning.
My church screen projector shows little bubbles on the screen and every time I put up worship songs or photos on the screen in church, you see bubbles, and It does not look good
If it's an LCD base projector, then you'll need to clean out the dust particles that have accumulated on the LCDs that will require you to open up the projector, which I wouldn't recommend if you're not too familiar as there are many components inside.
Jun 22, 2015 | Office Equipment & Supplies
Dc59 I removed the clear canister but the inside with the chambers with a mesh cover are filled with a fine powder. How to I clean?
I have the same buildup of very fine, powderlike, dust/dirt particles behind the mesh screen.
I do not doubt your technological explanation as to why/how this accumulation has occurred but there is another issue created by this buildup and an concern to go with it.
The issue is that this accumulation literally stinks. We have 4 cats and a dog which is likely why there is such an odor. There must be a way to remove this stuff.
The concern is that, after putting up with the stinky Dyson and the continued accumulation, the "dust" will eventually completely fill the space behind the mesh screen. When that screen is completely filled is the only solution we have is to spend another $600 for a new Dyson?
The Dyson is not your typical disposable technology that we often buy today. We chose to spend the extra $ for the Dyson because of the spirit cleaning of the unit. Had we known the unit would, within 6 mos., begin to stink and would likely need to be thrown away within two years we would have purchased a less expensive brand.
Since we have learned now that Dysons are stinky and disposable units we can run it under water, let it dry and hope for the best?
Mar 01, 2015 | Dyson DC59 Motorhead Bagless Cordless...
Philips 42PFL7662D problem
I come across this every day with LCD Tvs.What it is, is dust between the layers of the LCD. When dust particles settle behind the front layer of the LCD, and the LCD is pressed i.e when cleaned, the layers can be pushed together, resulting in a shadowy streak. If the LCD is stripped and cleaned it will be ok.
Feb 24, 2010 | Philips Televison & Video
Yellow spots on the projected image
Hello there. First, some info you need...Green LCD=purple onscreen, Red LCD=cyan(baby blue) onscreen, and Blue LCD=yellow onscreen.
These spots (specks?) are probably dust particles that get past the filter. Annoying but harmless. To check if they are indeed dust bits, if you can focus sharply on them, then yes, its dust. To remove the particles completely will require a service. They will only return eventually. You can try to blow out the biggest offenders with some canned air. And, to help slow down dust entry, keep the dust filter cleaned so that the unit always has plenty of air movement--you'll have a cleaner image with the added benefit of LONGER life of the lamp and projector components (dust is the number 1 killer of projectors)
Aug 30, 2009 | Epson PowerLite® S4 LCD Projector
DARK SHADOW EFFECT UPPER CORNERS OF SCREEN
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Water marks and dust on the INSIDE of Nokia 6085 LCD screen
Brother Frist Time I Am Faseing Problem Like This Its Unbelievable, Go 2 service Senter & Chaque Handset For Other Dameges.
Mar 31, 2009 | Nokia 6085 Cellular Phone
Dust in my Kodak m863 lcd screen
Hold the camera upside down and gently blow off any grit and lose dust particles. Next lightly wipe the lens with a few drops of lens cleaning fluid, place the fluid on the lens cleaning paper, not directly onto the lens and then wipe the lens.
Feb 04, 2009 | Kodak EasyShare M863 Digital Camera
Dust behind screen
take off the screen cover (the plastic) with a pin and clean it with a (magic) cloth.
Jul 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Sony 61" lcd has bluish spots in screen, any ideas?
Hello, inside the set there is an optical unit with 3LCD panels. Somehow the dust particles came into your set and now the dust is all over the optical unit and 3LCD panels. Only way to solve this issue is to clean the dust. Please contact your Sony dealer. Best regards, Arpi
Jul 10, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Lenovo L215p 21.5 Wide Screen Full HD LCD Monitor Logo
115 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
