Question about Minn Kota Maxxum 55 Bow Mount With Speed Coil
No Power I don't have any power to make it work. Brand new battery and all of the plugs are on correct and in.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Take the cover off to expose the connections and put a volt meter on the incoming battery terminals to see if you have 12 volts at the head. if you do then check the leads heading down to the motor to see if you have voltage there as well. if you dont you may have a bad switch. hopefully you just have a loose or undone connection. if you need to troubleshoot it farther call the 800 number on the head minn kota and their tech people will fax you info or walk you through the process.
Posted on Jun 02, 2010
My brand new samsung s760 camera wont turn on
Charge for 1 hour.
Pull battery's and see if they have power.
If Power is good Make sure they are in correctly
If Dead Replace battery's. ,
The only other thing it Might be, You said the Camera was New, But if the battery's hold a charge the Battery Door might have lost it's Contacts and the battery's won't work without it, It may have been returned to the store before you got it..
Nov 09, 2013 | Samsung S760 Digital Camera
Why Power Tool batteries can't charge to 100%?
Batteries wear down over time. The cells inside them don't work as well at holding a charge compared to when they were brand new. So after using them for a while they begin to last a shorter amount of time.
Lithium Ion batteries last longer and don't wear out as quickly. NiMH batteries are next in reliability. And NiCad have their own issues.
Aug 13, 2012 | Drills
Brand new phone, will not charge. have plugged it in. batteries test out ok. however it looks like the base units are not picking up the charge. brand new phone. trying to use it in bangalore india where...
Take it back to where you got it and demand a replacement. Usually I stay far away from extended warranties but in the case of telephones I make an exception. They are made very cheap these days and don't last very long.
Aug 20, 2011 | Panasonic KX TG4053 19 GHz Trio Cordless...
My wife plugged in her lap top( gateway N58) with my son's plug-in for his notebook, the difference in power is 0.5A/imput ( less for the notebook), same 19 volts,but less output AMPs 1.5A notebook /...
The power receptors next to the battery sound like toast. Try running the computer off of just the charger (correct one) with no battery. If this works, you need a new battery. If this doesn't work, your computer needs a new power supply. Hope this helps =]
Mar 01, 2011 | Gateway Computers & Internet
Dell laptop Will not charge, brand new charger still ran on the lil battery charge that was left in it. Wondering if the part that plugs in is loose or what u may think the problem is, thanks alot!
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Dec 23, 2009 | Dell Computers & Internet
Brand new battery & ac adapter not working on MX3702
If you've replaced both the battery and the ac adapter then the fault lies in the charging circuit of the motherboard and generally that is either a motherboard replacement or having the power connection on the motherboard by a service center, either way usually about $100
Dec 12, 2009 | Gateway Computers & Internet
Presario f700 no fan/lights = nothing at all. The charger works
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
My battery wont charge and its brand new
Did you put the battery into the charger in the correct way? Is charger plug into outlet that has electrical power "ON"?
Jun 30, 2009 | Porter Cable 19.2V Drill/Driver
NO Power
Possible causes Solutions
/ Corrective Actions
The power does not
turn on.
The ViviCam 6300
suddenly powers down.
The image is not
captured when the
shutter button is
pressed.
The flash does not fire.
Continuous shooting
is not possible.
Cannot transfer files
over a USB connection.
* Load new or fully charged battery.
* Load the battery in the correct direction.
* Close the battery cover correctly.
* Properly connect the AC power
adapter.
* Set the option of Auto Shut Down to Off.
* Turn the power back on or charge the
battery.
* Rotate the mode dial to A , P , SCENE
, Tv , Av or M.
Transfer the desired files to your
computer and then delete unnecessary
files, or use a different memory card.
* Select a different flash mode.
* Select [Single] in the capture mode .
* Insert a new SD memory card.
* Check all connections.
* Install the USB driver on your computer.
* Turn on the ViviCam 6300.
* The battery has run out.
* The battery is not oriented correctly.
* The battery cover is not closed properly.
* The AC power adapter (optional)
is disconnected.
* The function of Auto Shut Down in
Jan 25, 2008 | Vivitar ViviCam 5386 Digital Camera
Notebook power problem
Good evening Arapa, Before I went any further I?d make sure the new A/C adaptor and battery are working correctly. Over the years I?ve had many brand new or refurbish parts wind up not working. Also verify that they are the correct ones for your laptop. The next candidate is the charging circuitry or power distribution in the laptop. Since it involves major disassembly I don?t usually recommend this option to the typical user unless they have experience working with and handling electronics, a good mechanical aptitude and are willing to live with the results of damaging the laptop beyond economic repair. Most times a local factory authorized and trained tech can give you a good estimate of what it will cost and save you the cost of buying test parts you may not need. Let us know how things turn out and don?t forget to rate the posting.
Jan 05, 2007 | Compaq Presario R3000Z Notebook
Minn Kota Maxxum 55 Bow Mount With Speed Coil Logo
104 people viewed this question
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
