Question about Acer Aspire One PC Notebook
Startup my laptop starts up and shuts down immediately. it's a 17" bought from NBC TV
    Scholar:
  • 75 Answers
Are you running your laptop on battery alone? If that's the case, run it with the charger plugged in. If that sorts it out then you need to change your laptop battery
or
Restart your computer, and then press F8 during the initial startup...
review the following recommendations and use one which applies. additional information can also be found on the same site.
good luck!
system restore tool at command prompt
http://support.microsoft.com/kb/304449/
restore the operating system to a previous statehttp://support.microsoft.com/kb/306084/
start your computer by using the Last Known Good Configuration feature
http://support.microsoft.com/kb/307852
Posted on Jun 02, 2010
My lil girl lost my disk to my Toshiba c855d-s5307 laptop and I'm locked out of computer please tell me how to do a factory reset or help me get in please
THROUGH F12 AT STARTUP
To access the System Restore, Refresh and Reset options using the F12 option at startup, perform the following:
  1. If not already, ensure the computer is completely shut down. How To: Shut Down a Laptop with Windows 8
  2. Now restart the computer by pressing the power button - IMMEDIATELY start tapping the F12 key on the keyboard until the "Boot Menu" screen appears.
  3. Using the arrow keys, select <HDD Recovery> and press "Enter".
  4. On the next screen you are asked to confirm if you want to continue with recovery. Select "Yes".
  5. The computer will bring you to the Advanced startup screen.
  6. Select Troubleshoot. Under Troubleshoot you will see "Refresh" and "Reset".
  7. Select "Advanced options." Located here is "System Restore."
Nov 17, 2015 | Toshiba Computers & Internet
Alienware 17" notebook with windows 8 shutting self down at startup
If it's 3 weeks old return it. Or you can do a System Restore/Recovery. Take a look at this forum for the Restore/Recovery Procedure: http://en.community.dell.com/owners-club/alienware/f/3746/t/19441985.aspx
Mar 01, 2013 | Alienware PC Systems Alienware M17X with...
How do you start in safe mode? I started with power and shift. Then what do I do?
To start up in safe mode:
Shut down your computer and wait 10 seconds.
Press the power button.
Immediately after you hear the startup tone, hold down the Shift key.
You should press the Shift key as soon as possible after you hear the startup tone, but not before.
Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
Nov 13, 2010 | Apple MacBook Mac Notebook
PC with windows xp professional , on booting , shuts down immediately everesince I uninstalled Nero Dvd writing programme
Reboot your PC and immediately start tapping the F8 key, then choose to start in safe mode. Now click the start button, then click run. Type MSCONFIG and choose startup programs and disable all startup programs and see if it boots ok. If it does you can retype msconfig and one at a time re-enable your startup programs until you find the one that makes your PC hang and reboot, Keep that one turned off after you find it, and re-enable the rest of your startup items.
Aug 30, 2010 | IBM NetVista PC Desktop
Startup switch on PB G4 17 not getting apple sound, takes numerous times to boot up. Using Tiger OS, upgraded to latest. Works fine, otherwise.
If a Mac is shut down while the volume is set to zero, the standard Apple startup chime will not sound, so it is impossible to say whether or not this symptom indicates a problem.
For a startup issue such as this, I would recommend zapping the PRAM and resetting Open Firmware.
To zap the PRAM, start with a powered-down machine, press the power button, then immediately hold down the four keys: command, option, P, R. After ten seconds or so, you should hear the optical drive reset, and then the startup chime (because the volume is reset to full by this procedure). Ten more seconds, another reset, another chime. After the second time you hear the chime, release the keys.
Shut the machine down again (if it doesn't start up successfully, hold the power button until the power goes off). Press the power button, then immediately hold down the four keys command, option, O, F. You will see some tech-speak on the screen, then it will wait for input. Enter the following three lines, pressing the "return" key at the end of each:
reset-nvram set-defaults reset-all
After the last line, your Mac will reboot itself. It should now boot much more reliably. If it doesn't, chances increase that you have a hardware problem. You may want to run the Apple Hardware Test from the DVDs that came with the PowerBook to check your memory and logic board. Failing this, you are in for a trip to the shop.
Oct 05, 2009 | Apple PowerBook G4 Mac Notebook
Travelmate 290 starts then shuts down
please re install the recovery software.
Dec 10, 2008 | Acer TravelMate 290 Notebook
Mac Laptop has black screen
Try starting in safe mode, this usually bypasses the graphics drivers, which could be in a funky state:
You should press the Shift key as soon as possible after your hear the startup tone, but not before.
Jul 31, 2008 | Apple MacBook Pro Notebook
PROTRON 26 IN
Be careful on buying a new TV's. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
Feb 24, 2008 | Protron PLTV-32 Television
Monitor shuts off after initial start-up
My 17 inch Norcent LCD was doing the same thing. Then after a couple of weeks the AC adapter failed. I got a new ac adapter now LCD is working.
Nov 21, 2007 | Norcent Technologies LM730 17" Flat Panel...
Hitachi 27AX1B immediately shuts off at startup
you are going into shut down check regulator check for bad solder connections get back to me
Nov 02, 2007 | Hitachi 27CX01B 27" TV
Acer Aspire One  PC Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
