Question about Lincoln Electric AC225 Stick Welder K1170
Would like online manual
Is it possible to get an online manual for parts for a Lincoln ARC electric welder AC225C
Thank you
Ron
  • 760 Answers
You can download your manual from the Lincoln web site:
http://www.mylincolnelectric.com/Catalog/lecooperatorsmanualsearch.aspx?cnt=0&keyword=ac-225
The picture displayed here isn't a AC225C I don't think, I think that's an S. In any event you can download whatever manual you need.Lotsa luck!
Posted on Jul 08, 2010
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
What is wrong with the idle on my welder? the switch works , it idles up when I switch it on high and it idles down when I switch it down but it wont go up when I strike an arc or use power tools, what...
There is something wrong with the auto load sensing switch which is part of the generator. That is the sensor that detects when current load from the generator drops as in when you strike an arc or turn on a power tool and cranks the throttle to full power. It is obviously working on manual because the manual switch is cranking the revs up so the solenoid that operates the throttle is ok. My advice is to take it to a service centre that deals in welder/generator sets as you are playing with dangerous voltages and may possibly damage the machine by tinkering with it or fry yourself (nasty)
Jun 27, 2014 | Lincoln Ranger 250 Gxt Welder Generator...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Will not weld or arc , I bought my ranger after hurricane ke ask a generator, and never elded with it. today for the first time I tried to weld with it and it will not arc
Make sure the WELD TERMINALS SWITCH is in correct position.: In the WELD TERMINALS
ON position, the output is electrically hot all the time.
In the REMOTELY CONTROLLED position, the output is
controlled by a wire feeder or amptrol device, and is electrically
off until a remote switch is depressed. If you don't have your manual, you can download one at http://www.mylincolnelectric.com/Catalog/operatorsmanualdatasheet.aspx?p=104081
Jul 18, 2010 | Lincoln Electric Ranger 305D K1727-2...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
I need to find a manual for a Craftsman welding stabilizer
I think most of the older Craftsman welders were made by Century which is now owned by Lincoln Electric Company. If this is a wire feed welder you adjust the wire feed speed so that the arc sounds like eggs frying, the voltage setting (if any) will depend on the thickness of the material you're trying to weld. If it's a stick welder there will just be a current range control that you set depending on the thickness and type of material you're welding.
Rank me if this helped,
Carl
Oct 17, 2008 | Welding Tools
Lincoln Electric AC225 Stick Welder K1170 Logo
384 people viewed this question
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
Daryl Gleaton
Troy
Troy
Level 1 Expert
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
