Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Briggs and stratton 5 hp motor wont fire
I have a pressure washer witha 5 hp briggs motor on it. It will not fire. I checked plug, sanded rusty area off fly wheel and made sure on-off switch wasn't grounded. Any tips on what to do next?
4 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Posted on Jun 02, 2009
  • 583 Answers
SOURCE: briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Posted on Oct 25, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Engine wont fire....
There should be 1 black wire that grounds the coil(s) for kill. Be sure this black wire is not grounded when switch is in on or start position. It will be connected to the coil(s) at the flywheel.
Feb 10, 2013 | Snapper 21 hp* Briggs & Stratton...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton miss fires on one cylinder.22hp intek
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine wont start.
REMOVE plug and put on to lead and rest plug thread on to a good earth on engine and pull starter cord ,, if spark you have fuel problem ,,If no spark try a nother plug if still no spark remove cowling and Flywheel assy and the spark coil is under the flywheel and the coil could be found faulty ,,if all rusty cleen mag and pick ups with 200 grit paper and refit in reverse of removal and start.
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
Not firing
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
No fire canged magnito & checked magnet
could be a low oil safety switch on the briggs & stratton gone bad. Try disconnecting it and fire it up.
Apr 26, 2009 | Briggs & Stratton Pressure Washer...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
416 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
