Question about Bush Audio Players & Recorders
How to set up a bush turntable mtt2 I have the record spinning but the sound is distorted, presumably i havent got the arm counterbalanced but there are no instructions with the turntable. What is the best setting?
djproaudio
  • 515 Answers
SOURCE: techniques SL-D1 Turntable anti skid...
Actually, this sounds like the needle is damaged. Make sure there is a tip on there. Just because it's new, does not mean it is not damaged. Sometimes end-users improperly handle the stylus/needle when installing.
If you are 100% certain that the stylus is ok, then the anti-skate needs to be set correctly. Generally, leaving it on 0 (zero) is ok to start. Then try and balance your tonearm according to THESE INSTRUCTIONS. These instructions apply to most turntables. The fundamentals are the same for all turntables in that you need to balance (float) your tonearm for optimal use.
Hope this helps some.
- Davis.
Digital Analog Therapy
Electronic Repairs
www.repairny.com
Posted on Nov 04, 2008
scope eye
  • 4 Answers
SOURCE: Old record player spins too slowly
it sounds as if the rubber belt is to slack however also worth checking ithe attachment to the spindle itself is not loose 2make sure the belt is the correct type
Posted on Feb 10, 2009
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
dunnbiker
  • 8546 Answers
SOURCE: Crosley CR79 4 in 1 Entertainment Center
Wild guess but try this with the power off. Rotate the platter clockwise about 5-10 turns. You may feel internal mechanical engagement as you do it. The cueing mechanism may cycle it through its motion and return it to the rest.
Posted on Apr 04, 2009
  • 69 Answers
SOURCE: Problem with Technics SL-BD20D turntable: Sound
have you got anti skate adjustment
Posted on Aug 07, 2009
Ion turntable
Could be, but check the wiring to the cartridge, plus the connection to your amp. A poor earth wire or one touching the other can make it sound tinny.
Oct 22, 2013 | Audio Players & Recorders
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
Can u tell me where 2 purchase a stylus 4 a bush acoustics mtt2 turntable
Google Phono needles and look there. There are several vendors that may have what you need.
Feb 14, 2011 | Kitchen Appliances - Others
This is a question for my daughter who lives in Japan. She has a Crosley turntable she bought from Urban Outfitters. The stylus arm has suddenly started skating over the record, ie won't play anything. ...
I have no experience of Crosley turntables, however, stylus arm skating across the record surface on any turntable is normally due to the counter balance weight being incorrectly adjusted. In order to track across a record properly, the stylus must press down on to the record very lightly. If there is too little pressure, skating is what tends to happen. Too much pressure can cause distortion of the sound and excessive wear of the record.
At the pivoting end of the stylus arm, there should be a counter balence weight. This is normally adjustable (but not always - depends on quality and features of the particular turntable), and is used to set the pressure the stylus applies to the record surface, measured in grammes. The manual that came with it should tell you how to adjust it, but for most turntables stylus pressure is between 1 to 3 grammes.
If you dont have the manual, have a good look at the pivoting end of the stylus arm to see if soemthing is obviously wrong, or if not whether there is something with numbers on it that can be turned or slid. This is likley to be the counter weight. Try adjusting it.
Within reason, the stylus weight isnt critical so a "trial and error" approach wont do any harm.
Nov 12, 2009 | Crosley CR249TA Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Feb 09, 2009 | Crosley Traveler Turntable
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Jan 03, 2009 | ION Audio iTTUSB Turntable
Sound very distorted
This turntable has a preamp switch on it, which is probably on and what is causing the distortion. Take off the metal record platter by lifting up on the two holes gently. Turn the pre-amp switch to 'off' and then try it again. This is probably it...
Or you can plug it into an input that doesn't have a preamp and that should work.
Dec 25, 2008 | Audio Technica AT-PL50 Turntable
499 people viewed this question
Top Bush Audio Players & Recorders Experts
 Grubhead
Grubhead
STEVEN MAYAMBALA
Level 1 Expert
Are you a Bush Audio Player and Recorder Expert? Answer questions, earn points and help others
