Question about Kenmore 53582 / 53584 Side by Side Refrigerator
Freezer and Refrigerator -- Not Cooling
Kenmore Cold Spot Side-By-Side
M/N 106.53582300 Mfg Date: October 2003
Neither the freezer or refrigerator are cold/cooling. This is a secondary refrigerator located in basement. It is relatively clean and probably opened no more than three times per week.
The lights come on and the fan is running inside the freezer. There is no ice build up or water present in the freezer or refrigerator. The door seals are tight and the coils underneath are clean. Area around refrigerator is the same as it has been for last several years. I have not tested anything, but I cannot hear the compressor running.
What are the logical steps for component testing? If the compressor is not running, I suspect the following components: thermostat, relay, overload or capacitor, defrost timer, condenser fan motor, etc.
I would like to know the best order of things to check and how to check the various components. I appreciate your advice and guidance.
Thank you.
Mike
5 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: kenmore freezer and fridge is not cold - not frost build up - compress anf fans are all running
You need a qualified technician for this problem.
- Your unit may have leaking try to check for oil traces.
- The system maybe restricted, system reprocess is needed for this unit.
- If the unit is no frost try to check if there is an air circulation inside the unit. If no air is present then check your fan motor inside.
Posted on Jan 11, 2008
22yooper
  • 828 Answers
SOURCE: Kenmore 596.72913200 Refrigerator is Warm, but Freezer is Cold
There should be a push in switch on the door frame that you can push to see if the evaporator fan is functioning. You will be able to hear it when you push in on the switch.
If your problem is defrost related you will see frost buildup on the back wall of the freezer . If it is defrost related it will be ether the timer, heater, or defrost thermostat that is your problem. If it is the timer, locate where the timer is. Sometimes located in the area of the temperature controls with a hole through which you can turn a clutch head screw clockwise very SLOWLY until you hear one audible click. This will start the defrost. if after 30 minutes it defrosts but does not start cooling again turn the screw just a little further and you will hear another click. The compressor should start. If this is you conditions the timer needs to be replaced. If it fails to defrost and restarts to cooling mode after 18-22 minutes the problem is in the defrost heater circuit.
Posted on Jun 03, 2008
tborn6
  • 700 Answers
SOURCE: refrigerator/freezer not cooling evenly top to bottom
good then go ahead and ohm out the sensor and the relays to see if the resistance is close to the normat. 70 degrees is roughly 1000 ohms. relay you are lookling for continuity or open. then you can also ohm the fan motor too. let me know what you find;.that will determin whts bad and whats good
Posted on Dec 26, 2008
paulm10
  • 73 Answers
SOURCE: Freezer cold. Refrigerator very warmer.
Hi there. This should be a self defrosting unit. Check the defrost clock. It's usually behind the grill at bottom front of frig. or near the compressor. There is probably a little window on the clock motor where you can see it turn. You can manually advance the clock to put the unit into defrost mode. Check the defrost heating element. This is the usual problem. It is under shrouds where all the frost builds up. If element good, check defrost thermostat connected to element mechanically and in series electrically.
Thanks
Paul
Posted on Jul 13, 2009
The freezer side is cold however no cold air flow is going to the refrigerator side
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 29, 2011 | Kenmore Side by Side Refrigerator
My older model kenmore side by side refrig. is not getting the frig or the freezer cold model#9545510 serial #SD4123102 mfg. date 10/94 please help is there something i can try first before getting a...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 17, 2011 | Refrigerators
Refrigerator not cold enough, freezer too cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 06, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Freezer side is cold but other side is not getting cold
heatman101
Nov 27, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot model 106-54592400. The refrigerator is not getting cold enough, has been hovering around 45 to 50. The freezer is working.
heatman101
Nov 10, 2010 | Kenmore 50522 / 50524 Side by Side...
Kenmore cold spot not cooling properly
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
jsrha
Apr 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
Jan 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 53582 / 53584 Side by Side Refrigerator Logo
95 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
