Question about Gateway DX4300-03 Desktop PC
HDMI port isn't working for multiple monitors
Im trying to get two montiors so that I have more screen space.
But the HDMI isn't recognizing my TV as a monitor.
I don't know what to do?
Thats a hdmi audio port not video.
Posted on Jul 12, 2010
    Guru:
  • 551 Answers
Set the display on you TV on HDMI so that you could test it.
Posted on Jun 02, 2010
    Champion:
  • 218 Answers
Is the card your using able to put out 2 feeds?
  • grant gillespie
    grant gillespie Jul 12, 2010
    if you have a hdmi card and linked it to the tv you might need to right click on the screen and set it to two outputs if its nivada its easy you can google it hope this helps
How can I connect my TV to a Dell laptop via HDMI?
if oyur LG tv has multiple HDMI ports, then you might need to choose the correct HDMI port from the 'INPUT' menu. Does the HDMI port on TV (sidepanel / back) has a sticker which denotes the number? if yes, then on tv remote, choose INPUT /SOURCE menu, it will show TV, Component, RGB, HDMI1 , HDMI2, HDM3, etc (depending your tv model, these options might vary) and choose the port number which you plugged the HDMI into. if you do not have a number on the port, then you might need to select each HDMI from "INPUT' menu and wait for a couple of seconds.
Sep 01, 2015 | LG Televison & Video
My Samsung r730 has a hdmi port can I plug my ps3 into it and use te screen like a tv
You might be able to do the same thing with Plex Media Server, it's free and works over wifi. Generally laptop HDMI ports are two way, and you determine screens etc through your video settings. Here is a link to Plex for Samsung. Appstore Overview Plex G00002687241 Samsung TV Blu ray Apps
Feb 18, 2015 | Sony Playstation 3 (PS3) Console
TV won't recognize PC through HDMI port anymore
Thanks for all the background, super detailed! I had a similar problem on a new Samsung that was really flaky with my HDMI from a raspberry pi. Would have to do all kinds of unplugging, cycling power etc like you're doing to get it to work. Once on it would work until I turned the tv off (actually doesn't turn off, but goes to sleep) and back on. Finally figured out that the resolution I was outputting wasn't supported, BUT sometimes it would work. Once I changed the resolution to a supported resolution it worked all the time.
Mar 26, 2014 | Televison & Video
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Im trying to connect my presario cq60 to my lg 32hl3000 tv through the hdmi ports but no picture shows on my tv. It says there is no signal?
Your television may have multiple HDMI ports. When going through main menu on the television, look to see more than 1 HDMI entry (typically numbered HDMI, HDMI2 etc). Try all HDMI available on the television until you see a picture of your notebook's desktop on the television.
Aug 20, 2011 | Compaq Presario CQ60-220US PC Laptop
ASUS Motherboard AT5IONT-I, Win7pro,4G RAM,SSD. Everything works fine with a screen plugged into the DVI connector. HDMI output does not recognize any screen, tried everything, installed latest Nvidia...
i have the same problem!
AT5IONT-I, Win7pro,4G, bios 0502
tried many screens, nvidia driver versions etc.
hdmi only works in single monitor configuration. hdmi blanks on detection of dvi monitor. argh!
Apr 18, 2011 | ASUS Motherboard AT5IONT-I Atom D525 ION...
Trouble connecting Insignia HDTV 19" to my macbook pro
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Gateway DX4300-03 Desktop PC  Logo
675 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
