Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
Scotsman Ice Maker Model # CME506AS-1H won't stop
We have a Scotsman Ice Maker Model # CME506AS-1H that will not shut off What can be done?
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
TheMobilian
  • 8220 Answers
SOURCE: Ice Maker not working
Start by cleaning the condenser with a brush and a shop vac. Then get some nickleguard ice machine cleaner and wash the units plate's down going by package directions, then retry before calling a tech. It may start working but if it does not then it may save you some money by having the unit clean before the tech gets there. Ice machines are not a DIY repair. Sowwy
Posted on Mar 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: Scotsman ice machine problems.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
Scotsman ice maker SCE170-1H NEED WIRING DIAGRAM
GO to Google, type in SCE170-1H Service Manual. When sites come uo look for the heading SCE170 Service parts-Scotsman ice Systems, click on that one it is a pdf go to page 9.
Sep 05, 2014 | Kitchen Appliances - Others
Scotsman MDT5N40W-1H I was told it has high head pressure. how do I fix it
First you need to find out what is causing the high head presser. First check the filters make sure there clean. Next check the condenser coil to make sure it is not dirty. Next check the condenser fan to make sure it is not dropping out. if this is all good then you will have to look for a internal restriction rather it is a stopped up dryer to a bad TXV valve. this should be done by a refrigeration mechanic.
Apr 17, 2014 | Scotsman MDT5N40W-1J Touchfree Water...
Scotsman sce275a-1h
Replace the din full sensors this will let the ice machine start up if the sump tray dose not start to fill up with water look at board to see if water full light is on if so replace water sensor that is in water sump tray. if light is not on then check to see if you are getting power to water valve if you are getting voltage to valve then check water filter dose it need to be replaced. now never use any thing other than ice machine cleaner made for ice machines it has to be nickle safe are you will dammage the evaporator plate.
Jan 23, 2014 | Scotsman Ice Machine - 290lb...
Scotsman ice machin model cme506AS-1F BIN FULL AND UNT OFF
Pull and clean bin full sensors or replace them then power unit back up.
Jun 26, 2012 | Scotsman Cooled Modular Contour Cuber Air...
The model for Scotsman ice maker is AFE400A-1B and it stop making ice. Can you help me diagnosis?
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order.
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Mar 15, 2011 | Scotsman Ice Maker WBin Flake Style water...
I have a Scotsman AFE400A-1H flaked ice maker, that has started to produce "dirty ice". I have read that the unit has a in-line filter, how do I access the filter, to clean or replace it? ...
Shut it down and have a professional look at it immediately. I do not know of an inline filter and the knocking noise indicates something really bad happening inside of the evaporator / auger housing.
Nov 24, 2010 | Scotsman 22 Wide Ice Maker Bin 242 lbs
We have a code 2 on the water light, cme506as-10, the solonoid isn't kicking in, Help
check float switch if its not functioning control will not no it is out of water so it will not engage fill
Aug 31, 2010 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
617 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
