Question about Konica Minolta bizhub C450P Laser Printer
NEED TO ORDER 4 BLACK TONER # TN310BK - Konica Minolta bizhub C450P Laser Printer
    Brigadier General:
  • 10,406 Answers
Search on 'www.ebay.com' for best prices for that part-number.
Posted on Jun 01, 2010
Whats the difference between the drum and the cartridge? What is the DRUM K? Is it the black toner?
If it's a colour/color printer, you will have 4 toners and 4 drums to put the toner onto the paper, CMYK is the order of things in colour printing and you are right about the K being the black.
Get a replacement drum should be easy enough, the photoreceptor may be simply dirty if it's not had a service for a while, if you know where they are, give them a wipe with a cloth or cleaning pad with Isoproyl Alcohol rather than Lemon Pledge or water...
Nov 05, 2014 | OKI C5500n Laser Printer
Blinking amber light next to black toner?
the blinking light means the toner is getting low
when the blinking light yurns solid its time to change the toner cartrige
Jun 12, 2014 | Dell 1320c Laser Printer
4 black lines at every print
Mostly black lines prints due to problem in the Black toner cartridge. remove the Black toner out and inspect the toner drum, whether are their any black patch on the toner drum. If it so there's a problem in the black toner. Replace a new black toner and check.
Jan 24, 2013 | HP LaserJet CP1215 Color Printer
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
Invalid black toner replacement cartridges
Hi, Please make sure what version printer you got? USA version? or Asian version or euro version?
After confirm what version printer you got buy corect version CHIP or toner it will works.
Use any of other area toner will result toner invalded.
Regards
May 20, 2009 | Samsung CLP 300 Laser Printer
My printer shows:order K toner
Get new OKI toner cartridge- Black is "K"
Apr 24, 2009 | OKI C5100n Laser Printer
Refurbished Canon PC 160
Yes...it's definitely the toner cartridge.
Erice
Oct 29, 2007 | Office Equipment & Supplies
Installing new black print cartridge
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Oct 21, 2007 | Minolta magicolor 2400W Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta bizhub C450P Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
