Question about Woods 59028 Programmable Timer Switch Light Almond
Help with Woods 59018/59028 7 day digital timer
I’m having trouble with this timer.
I installed it last night but having wiring issues.
The wiring diagram shows connecting white and red from the timer to the neutral. Black to hot.
No ground in the box so not using it.
When I do this combination, the timer clicks and blinks the light continuously.
So I switched hot and neutral from the house side and same thing happens.
If I don’t use the red wire, the light does not work. I haven’t tried red and black connected only.
What am I doing incorrectly?
    Guru:
  • 351 Answers
The usual connection for this type timer is the house black power to the timer black, the house white power to the timer white and the , the light black wire to the red timer wire.
If you only have two wires, one black and one white, at the switch location, then you cannot use this style timer , as it needs a neutral. You should return this timer and get one that does not require a neutral connection.
Please Vote !!
Posted on Jun 01, 2010
Lights blink when in manual mode
If this is new installation, then Timer is wired wrong:
If timer worked before, then it has gone bad, buy anotyher timer
Copy following links to identify type of timer, single-pole, 3-way etc:
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
hh
Sep 24, 2013 | Woods InWall 7 Day Digital Programmable...
Lights are blinking after setting up the timer
You connected white wire and red wire together.
No harm done.
ez to fix.
Woods 59018 is single pole timer.
Copy following link to see step-step for wiring single-pole timer:
Add a comment as needed
Jul 08, 2013 | Coleman Cable Woods 59018 InWall 7Day...
I'm looking for a timer to replace the thermostats for 2 furnaces in a riding arena.
1) Yes a spring-wound timer will work.
Woods 59717, Intermatic FD60, etc
There are other models depending on length of time, and color of timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
2) How to wire to 24 volts
24 volt circuit has 2 wires going to load.
Cut one of the wires and then connect cut wire to timer.
3) Buy Woods 59717 or Intermatic FD60 timers at Amazon.com in home improvement.
Both products have 1 year warranty, and both are strong companies.
Spring-wound timers last many years, and set-times are approximate.
Jan 03, 2013 | Woods 60 Minute Spring Wound Timer in...
Sunset sunrise doesn't seem to work anymore
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aug 05, 2011 | Woods InWall 7 Day Digital Programmable...
Just installed a in-wall digital timer model 59018 and when we try to program it when we hit the clock button the unit shuts off so we are unable to set the time (or anything)
Woods 59018 single-pole 7-day 7-program timer, color white:
I test timers and 3-5% arrive defective, and they never work. Some stop working within 1 year, and some last quite a while.
Timers are affected by line interference and polarity issues. So wiring in home has to be correct before timer will operate as expected.
Timer has to be installed correctly with each wire correctly connected.
Press manual override button and see if lights turn on-off. This will indicate if your timer is wired correctly. If lights do not turn on-off with manual override, the open link above for wiring instructions.
To begin programming, reset timer by pushing in the round reset button with toothpick or paper clip.
12:00 am Mon should display.
If the above items are all correct, then defective timer is suspect.
If you try multiple timers, and each timer has same problem, then line interference or bad wiring is suspect, or you are buying from somebody who has a bad batch of timers.
Try wiring same timer at neighbor's house and see if it works there.
Jul 04, 2011 | Woods InWall 7 Day Digital Programmable...
Have programmed this timer twice. Set for 7 days a week to come on at 8AM and shut off at 10PM. It only lasts on automatic for two days then shut offs. When checked it has jumped two hours and is in...
You posted under Woods 59403, which is also sold under different brands and numbers
Open following link to identify timer and download on-line manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
1) I test timers. Some arrive defective.
People write to fixya reporting glitches and problems with this timer.
However, fixya might show complaints because timer is popular. After all, if nobody bought certain brand car, there would be few complaints.
2) This timer resets after power outage, so if you have loose wire, then timer will reset.
3) Timer problems are also associated with interference, noise, or bad wiring. Buy cheap circuit analyzer at home center and test by plugging into outlet.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
4) Try timer on different circuit, for example indoor circuit, and plug in different load.
5) Above information should narrow down if timer is defective, or if wiring or load are causing problem. Return defective timer to Home Depot, Lowes or Target and buy another.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 17, 2011 | Woods Outdoor 7 Day Digital Two Outlet...
I have the Woods 59018 In-Wall 7-Day Digital Timer, and am having trouble installing it. I am replacing an IntermaticModel EJ251 timer that only connects using two black wires in the junction box (as...
Open following link to identify timer, read wiring instructions, and download on-line manual:
How to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push timer door which is also the ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Mar 06, 2011 | Coleman Cable Woods 59018 InWall 7Day...
I lost the installation & how to program infomation.
Woods in-wall 59018 is programmable timer:
Woods 59203 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Woods 59337 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59377.pdf
Older style Woods 49556 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
If your timer is not listed, add a comment with description of timer
Nov 15, 2010 | Woods InWall 7 Day Digital Programmable...
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
Woods 59028 Programmable Timer Switch Light Almond Logo
1,140 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
